Code 20 and left over wire from ITR swap
Old Sep 9, 2003 | 09:58 AM
nolimits's Avatar
Default Code 20 and left over wire from ITR swap
I swapped a 97 JDM ITR into a 00 Civic SI using the SI harness and 96 JDM ITR ECU (with conversion harness). I had to extend the IAT wiring to the intake. I tied back 2 different Emissions connectors(charcoal cannister under battery and purge solenoid by fuel rail). I disconnected the secondary o2 sensor (unsused by JDM ECU). I also tied back the VTEC solenoid pressure sensor connector (unused on JDM ECU). I have a remaining square 2-pin connector underneath the intake on the driver's side that I'm unsure of. CEL light isn't on and the engine runs great (with the exception of a 1100rpm idle). When i ground the service connector it flashes a code 20(ELD). I figure a disconnected sensor would throw the ELD code, and with 1 connector left over that seems to be my problem....A/C pressure, Knock, and Oil pressure are in that area, but all are connected. Any Ideas?
Old Sep 15, 2003 | 11:43 AM
nolimits's Avatar
Default Re: Code 20 and left over wire from ITR swap (nolimits)
After some thought, I may know what the 2-pin connector is for (White/Red & Blue/Red Wires). On the B16A2 there was a crank sensor that I'm pretty sure used this connector.........does the 97 JDM ITR have this sensor?? I don't see any wire/harness exposed around the timing cover to plug into. I didn't see a plug on the JDM harness either.
Another note on the idle........the IACV is correcting the idle to 1100 so it's not a vacuum leak. When I disconnect the IACV the idle drops to ~750rpm.
DC2-ProdUcTiOnS
Aug 8, 2016 08:47 AM
bad23591
Jun 3, 2014 04:16 PM
gonein60seconds
May 5, 2011 01:34 PM
Metal Head
Sep 15, 2006 02:35 PM
Ls1 FD3s
May 18, 2004 12:19 PM
