civic si 99 ecu fit in a 99 civic hx?
Re: civic si 99 ecu fit in a 99 civic hx? (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">I don't see why not. You might wanna try the EG/EK forum.</TD></TR></TABLE>
second that
but to answer the question...... YES.... bc both cars are OBDII..... the ecu pins are the same.
second that
Re: civic si 99 ecu fit in a 99 civic hx? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Let us know how an HX performs when the 2nd intake valve doesn't engage until 5500 RPM </TD></TR></TABLE>
lmfao
lmfao
Re: civic si 99 ecu fit in a 99 civic hx? (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">99 Civic ECUs should be interchangeable.</TD></TR></TABLE>
99s are interchangable.
Do not use the SI ECU on the HX. The HX VTEC is supposed to engage at 2700.....NOT 5500!
Re: civic si 99 ecu fit in a 99 civic hx? (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
Do not use the SI ECU on the HX. The HX VTEC is supposed to engage at 2700.....NOT 5500!</TD></TR></TABLE>
true..
thats what the vtec-e is for so economy vtec kicks in earlier
but yes, interchangable
true..
bwahahaha that was great
Re: civic si 99 ecu fit in a 99 civic hx? (HybridcivicLS-T)
I wanted to know if it plugs in if i have confused anyone cause i know the 01 itr ecu doesnt plug in the 96 civic ex coupe but the gsr ecu plugs in the
Re: civic si 99 ecu fit in a 99 civic hx? (AlienKrOZ)
Naw i happen to know what its like when a hx has no vtec-e.
Someone toyed with my vafc oneday (reset it) and i found out the hard way.
Car took off good till about 3500rpms then it just starded screaming (at this point im thinking to my self WTF wondering if i blew off the itercooler piping)
At 5500rpms it felt like a 50 shot under the hood.
The tires chirpped HAHA.
Like I said above, I believe the 99-00 HX uses the 96-98 plugs not the 99-00 style. It won't plug in.
brian g
brian g
AlienKrOZ
10-22-2003 08:27 PM
