chipped p28 problems
Old Apr 1, 2004 | 10:36 PM
project_hatch1.8's Avatar
Default chipped p28 problems
i have a mugen copy chipped p28 for my b18c1 with a skunk2 itm, i prefer to use this because then i dont have the big flat spot from 4400-5800rpm like i do with the p72. vtec engages at 5700 and its suposed to redline at 9200 but it keeps the stock revlimiter at like 8600 or somethin like that. i know its not just a bad chip because i used my friends chipped p30 and it did the same thing. ive used this ecu in other cars and it worked fine, and it used to in mine. what could be causing this? help please
Old Apr 2, 2004 | 12:33 AM
Downey's Avatar
Default Re: chipped p28 problems (civicbhatch)
so your saying your ecu (9200rpm redline) actualy redline at 9200 in other cars except your own?
hmm, never heard of that before. you have no check engine light right?
i hope you have a good valve train to rev that high.
Old Apr 2, 2004 | 06:16 AM
well i just have itr springs and retainers right now so i dont wanna take it up to 9200, just like 8700, and no check engine light, and ya it works in other cars but not mine, i dont get it. im goin to be gettin some new cams and valvetrain but i wanna figure this out so i can rev higher. help me please. TIA
Modified by civicbhatch at 11:09 PM 4/5/2004
Old Apr 5, 2004 | 02:11 PM
Default Re: (civicbhatch)
and remember it USED to work in my car, i dont know when it stopped but if i had to guess ited be around the time i got my pistons in if that helps.
Old Apr 5, 2004 | 09:53 PM
up, i need to figure this out!!
Old Apr 6, 2004 | 12:06 AM
hndarcrb18c1's Avatar
Try checkin your tach.... They get out of calabration after a while...
Old Apr 6, 2004 | 12:38 PM
Default Re: (hndarcrb18c1)
thanks, anybody else?
Old Apr 18, 2004 | 09:48 PM
up again i need to figure this out.
update: i now have a CEL its my o2 sensor, and i got a vafcII and my tach is way off in some areas, but the vafc shows my redline at 8200, just like the tach says. i dont get it, this ecu works in other cars, just not mine
Old Apr 19, 2004 | 07:40 AM
come on guys, somebody has to know about this
Old Apr 19, 2004 | 10:38 AM
badboypolar
Guest
Posts: n/a
Can we see a pic of the P28 (the inside of course) where the chip goes. Can help you out better If ic an see it.
Also you not listing enough info for anyone to help you. It's kind of weak in the area of explantion, but then again I don't really understand your question.
If the chip revlimit is set to 9200, then it is 9200 no matter what ECU it is in.
Old Apr 19, 2004 | 11:22 AM
Katman's Avatar
I say you have an ecu reprogramming person (such as mua) have a looksy at your program and change your redline point
Old Apr 19, 2004 | 12:49 PM
Default Re: (Katman)
but i tried a another chipped ecu that works in my friends car, but it still kept the stock redline in mine, so i dont think its somethin with the ecu, because ive switched them and none have worked
Old Apr 19, 2004 | 01:33 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicbhatch &raquo;</TD></TR><TR><TD CLASS="quote">but i tried a another chipped ecu that works in my friends car, but it still kept the stock redline in mine, so i dont think its somethin with the ecu, because ive switched them and none have worked</TD></TR></TABLE>
have you wired in the VTEC solenoid and/or are you using an MSD box?
Old Apr 19, 2004 | 09:38 PM
ya, im using a msd box, whats that mean, or whats the signifigance of that? thanks
Old Apr 19, 2004 | 10:39 PM
What rpm pill is in the msd????
Old Apr 19, 2004 | 10:45 PM
hm...ive never looked, i bought it used, do i just take the cover thign off and it should be in there?
Old Apr 20, 2004 | 07:55 AM
Is it a red msd box or a grey one??
Old Apr 20, 2004 | 08:16 AM
grey, i just looked and the pill is on the side, and sure enough its an 8000 pill, damn i feel stupid. anyways thanks a lot guys for helpin me out oh and if anybody has a 9000 or 9200 pill they wanna get rid of let me know. thanks again guys
Old Apr 20, 2004 | 10:36 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicbhatch &raquo;</TD></TR><TR><TD CLASS="quote"> grey, i just looked and the pill is on the side, and sure enough its an 8000 pill, damn i feel stupid. anyways thanks a lot guys for helpin me out oh and if anybody has a 9000 or 9200 pill they wanna get rid of let me know. thanks again guys</TD></TR></TABLE>
lol..no problem.
Old Apr 20, 2004 | 12:52 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
i believe if you remove the pill completely then your ecu redline will take over
Old Apr 20, 2004 | 04:17 PM
Default Re: (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">i believe if you remove the pill completely then your ecu redline will take over </TD></TR></TABLE>
can anybody confirm this? if so thated be tight, then i dont even need to wait to get another pill
Old Apr 20, 2004 | 05:54 PM
krazie1's Avatar
BANNED
first check that
and does it sound like a red line and no power at this rpm on vafc2 right
well mine used to do that at 6200 or below and it was since the rebuild some junk got clogged in the vtec solenid screen???
or also can be the dizzy acting up???
I would check it out
mine would work on my friends car too and it was that
after I cleaned it I could feel really power again
P h i l
Oct 14, 2020 01:48 PM
mesmvc2
Aug 7, 2006 03:03 AM
BoredRec
Sep 27, 2004 09:31 PM
S@nt0s
Nov 24, 2003 05:39 PM
