check engine question obd2 to obd1 converted
Old Jun 12, 2007 | 01:16 PM
ekhatch978's Avatar
Default check engine question obd2 to obd1 converted
so i have a 95 gsr in a 97 ek, im using my factory harness with a jumper for a p72. just got it started over the weekend and its giving codes. is it even possible for me to check the codes? i have a fuel leak at the rail but thats not major and im not sure it would give a code. the car only stays on if im giving it gas too but i dont want to play with the idle until after i fix the fuel problem. any help?
Old Jun 13, 2007 | 12:06 AM
Hybrid96EK's Avatar
Default Re: check engine question obd2 to obd1 converted (ekhatch978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatch978 &raquo;</TD></TR><TR><TD CLASS="quote">so i have a 95 gsr in a 97 ek, im using my factory harness with a jumper for a p72. just got it started over the weekend and its giving codes. is it even possible for me to check the codes? i have a fuel leak at the rail but thats not major and im not sure it would give a code. the car only stays on if im giving it gas too but i dont want to play with the idle until after i fix the fuel problem. any help?</TD></TR></TABLE>
Yes you can check the codes still. Bridge the two pin service connector in the passenger side floor and read the codes.
chippinpressure
Engine Management and Tuning
Jan 14, 2010 05:47 PM
xft
Feb 15, 2009 11:12 AM
drkns
Jul 21, 2006 09:11 PM
yellow93delsol
Apr 7, 2004 05:17 AM
hybridDC4
Oct 26, 2002 03:37 PM
