Check "codes" on Civic/H22 swap doesnt work??
Old 10-30-2005, 10:32 AM
fastrcars's Avatar
Default Check "codes" on Civic/H22 swap doesnt work??
Hey..
Got a P13 ECU in my civic along with the H22 engine and the ESI (125hp Vtec version) wires...trying to jump the connector (see the left in the pic) to see the codes in the cluster..but it doesnt work..how should i do?
Old 10-30-2005, 01:57 PM
fastrcars's Avatar
Default Re: Check "codes" on Civic/H22 swap doesnt work?? (fastrcars)
Getting crazy about this s*it ..plz help me anyone nows..
Can i jump the ECU in any how?
Old 10-30-2005, 03:54 PM
lak8's Avatar
Im pretty sure its the smaller harness that is inside that green rubber boot (orange and green wires). All the ones ive worked on there is only one small connector. Thats why im not 100% sure, maybe some one can confirm.
All you need to do is jumper it (connect both wires) and it should show you the codes on the dash using the check engine light
Old 10-31-2005, 01:22 AM
fastrcars's Avatar
Well..it doesnt work..cause i made this swap..and i kept the original Dash and gauges..so maby thats why it doesnt show me the codes?..
Old 10-31-2005, 06:44 AM
antivic's Avatar
Default Re: (fastrcars)
take the one with the brown wire in it, and jump it with a pin or something, or cut the connector off and just put those wires together, turn the key to accessories and bam blink blink blink and if it stays on, u have no codes!, and then try doin it with the car on, maybe it'll pick up other ****.
the other blue plug is to set base timming, when checking ur timing with a lgiht
Old 10-31-2005, 11:05 AM
fastrcars's Avatar
Well..i jumped both of them..but nothing happens..these cables i got is made for civic ECU..but now its hooked up with the P13..sure these 2 will work anyway?..
Old 10-31-2005, 06:54 PM
Turbogixxer's Avatar
What cables are you talking about?
Does the check engine light even turn on when you first turn the ignition to the "on" position?
If so, try grounding D4 on the ECU connectors. It does the same as looping the service connector, but directly.
The other connector is for data, do not loop it.
Old 11-02-2005, 04:08 AM
RTFM
v4lu3s's Avatar
that is the check engine light jumper on the left.
when you jumper it what happens?
is the check engine light turning off or does it stay solid?
Old 06-26-2010, 08:54 AM
hondare's Avatar
i have the same prob. i jump the wires and no codes come out. i ground the ecu and still no codes still. the check engine light stays solid. w/o the wires jumped i turn the car to on the check engine light comes on than turns off then like 3 seconds later it comes on and stays on. wtf. should i buy an obd 1 reader. i dont want to because there a lot of money to only need once.
Davi_Vtec
03-11-2012 12:06 PM
jojo ethan
10-20-2010 07:02 PM
RooSter
11-22-2007 04:31 PM
H22CIVICJDM
01-08-2007 09:00 AM
Quick Reply: Check "codes" on Civic/H22 swap doesnt work??
