HELP!!!!!!!!! H22 civic
my civic i jus bought had a h22 swapped in it...the car ran fine i was cleaning it up n all of asudden is boggin now it wont rev past 4 rpm n it shakes alot...is it the ecu? it has a gsr ecu in the meantime i get my h22 could that be it too??
Re: HELP!!!!!!!!! H22 civic (djsire)
no water invlove3d is just that it was a swap so it has alot of dangling wires so i just wrapped up n taped some of those wires to make the engine bay look clean
Re: HELP!!!!!!!!! H22 civic (dvd_lettermen)
with that bogging, it could be the dizzy. try swapping it out with a friends to see if thats the problem. also, check to make sure there is no water in the spark plg chambers. the last thing to check is the ECU. make sure all connectors are correct and find out where those loose wires are from.
Re: HELP!!!!!!!!! H22 civic (bigl1986)
das what ima do follow the wires from the ecu and see was up ill get back to you guys on this thanks.....have pictures coming up !!!
