CAR WILL NOT START
Old Apr 1, 2006 | 09:20 PM
stevn's Avatar
Default CAR WILL NOT START
i swapped in a b18b into my 1992 honda civic vx. i used my vx harness and extended the o2 sensor wiring. the harness worked with the old b series that i had in the car. i have spark, fuel, fuel pressure, and compression. the car will not start. what could the problem be? i used the ls computer also.
can anyone please help me? i have been stuck for a couple of days.
Old Apr 2, 2006 | 09:32 AM
Terrible One's Avatar
Default Re: CAR WILL NOT START (stevn)
any cel? does the motor crank?
Old Apr 5, 2006 | 11:22 AM
jdmcars.com's Avatar
Did the motor start from the old car you pulled it from or do you not know?
If you have (and you are sure) fuel, spark, and compression, the only missing link is TIMING -that is all that is needed for a combustion. Make sure the car is in-time; and double check that you have spark, and make sure you have fuel on the plugs, etc.
Old Apr 5, 2006 | 12:34 PM
stevn's Avatar
Default Re: CAR WILL NOT START (jdmcars.com)
https://honda-tech.com/zerothread?id=1579904
this thread is everything that i have already done
Old Apr 6, 2006 | 07:41 PM
abbas's Avatar
check timing or the bolt on water pump housing if its ground and any other grounds
Lou845
Jul 26, 2012 04:03 PM
ORguy
10
Mar 22, 2011 05:25 PM
McLovin
25
Nov 5, 2009 10:44 PM
kelviiv
Dec 17, 2008 11:19 AM
brokenojoke
Mar 9, 2008 10:22 AM
