What is a hydro tranny?
Re: What is a hydro tranny? (mOuse)
Hydro Trannys are hydrolic fluid to help you shift where cable trannys a manual one and your arm is what provides shifting force. What kind of car do you have? I belive 92 and up honda's all have hydro trannies, but I could be wrong.
Re: What is a hydro tranny? (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer »</TD></TR><TR><TD CLASS="quote"> I belive 92 and up honda's all have hydro trannies, but I could be wrong.</TD></TR></TABLE>
I know 92+ Civics have a hydro tranny, but I thought only 94+ tegs had hydro tranny.
Re: What is a hydro tranny? (96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96coupe »</TD></TR><TR><TD CLASS="quote">
I know 92+ Civics have a hydro tranny, but I thought only 94+ tegs had hydro tranny. </TD></TR></TABLE>
Probably right I forgot about the 93 DA integra's.
Former Moderator
Yes basically trannies are divded into two categories when it come to D and B sereis trannies:
Cable - uses a cable to pull a clutch actuator arm.
Found on 1988-1991 Civics and 1990-1993 Integras and JDM "first=gen" B16A swaps
Hydro - Uses a hydrolics system like your brakes to push a clutch fork to actuate the clutch. Uses a master cylinder and slave cylinder and hard and soft lines and it holds fluid just like a braking system does.
Found on 1992-2003 Civics and 1994-2001 Integras USDM or JDM.
Why are you asking? Looking for a B16A swap and seeing really cheap "cable tranny" versions perhaps?
If it's for your 1993 Civic, then do yourself a favor and just buy the more expensive "Second gen" swap and save yourself some headaches of the cable tranny ****.
Re: What is a hydro tranny? (B18C5-EH2)
No, actually i was lookin at a H22a that said hydro tranny add 150$, so i just had no idea what it was becuase, i plan on a swap but i am learning as i go along.
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mOuse »</TD></TR><TR><TD CLASS="quote">No, actually i was lookin at a H22a that said hydro tranny add 150$, so i just had no idea what it was becuase, i plan on a swap but i am learning as i go along.</TD></TR></TABLE>
that's odd, because all of the H22a tranies should already be a hydro-actuated clutch with cable-type shifter instead of the rod-type of B and D series.
What site is this on? Are you sure it didn't say "LSD add $150.00" or something elseT
