best b16a cams?
Old Jul 15, 2001 | 08:34 PM
Atiyeh's Avatar
Default best b16a cams?
im thinking about getting some used type r cams, what gains should i expect from them and what other cams would you recomend, im never going turbo or going completely psycho with this motor. I just want a lil more pickup. Thanks
Old Jul 16, 2001 | 01:44 AM
B16CRX's Avatar
Default Re: best b16a cams? (elusiveracing23)
Type R cams are probably the best for what you want. If possible, use the CTR intake cam. Slightly better than ITR, but just slightly. Exhaust cam is the same.
JUN and Toda also make good cams that come in different stages if you want serious power.
Old Jul 16, 2001 | 07:36 AM
itrhybrid's Avatar
I would say best bang for the buck would be the CTR intake cam and ITR exhaust cam. If you can afford a little more, go with some toda cams. You'll definitely want a valve train upgrade with the Toda's though.
Good luck,
James
Old Jul 16, 2001 | 08:43 AM
Atiyeh's Avatar
Default Re: best b16a cams? (itrhybrid)
what about type r cams, would i want to do the valves for the r cams? and wwhat should i expect to gain from all this ?.. thanks
Old Jul 16, 2001 | 08:44 AM
Atiyeh's Avatar
Default Re: best b16a cams? (B16CRX)
your in hb?.. i was in irvine for a while there.. in buean park now
Old Jul 16, 2001 | 11:16 AM
itrhybrid's Avatar
I would say to upgrade to at least TypeR springs if you are going with R cams. Portflow also makes some good inner springs and Ti retainers. Price is pretty reasonable actually. The ITR outer springs are good for almost anything. At least for Toda Spec B cams. For instance I will be running Toda Spec B cams, Portfow inner springs and Ti retainers in my ITR motor when I get them. (If my damn stock would ever go up!) Oh and cam gears as well. Must for tunin purposes
As always take th time to dyno tune what you have done. As far as gains, I think the norm is about 10 WHP. More than likely you could get more if you have the means to tune them. Good luck
James
Old Jul 16, 2001 | 08:12 PM
Atiyeh's Avatar
thanks
Old Jul 16, 2001 | 08:38 PM
3.3.3's Avatar
T O D A
Old Jul 16, 2001 | 09:49 PM
GZR4DR's Avatar
Default Re: best b16a cams? (spnhb)
Hey B16CRX. Your in HB right? Which part, because i live there to. BTW your email address is almost the same as mine. Crazy ****. I'm a little younger however, but man that is wierd. Plus your first name might be the same as mine to.
Anyways, to answer the question ITR cams are the best bang for the buck. I made 201whp on my GSR motor a while back with those cams.
Old Jul 17, 2001 | 12:23 AM
B16CRX's Avatar
Default Re: best b16a cams? (GZR4DR)
Yeah, I'm in HB. Warner between Goldenwest and Springdale.
psegs80
K Series
Nov 25, 2009 08:27 AM
knitecrepr
11
Nov 2, 2008 07:58 PM
lsvtec101
12
Apr 11, 2004 11:38 AM
mj_speed
Dec 17, 2003 12:11 PM
DOHCRX
Jan 30, 2003 12:05 AM
