b20vtec supercharged...
Old Dec 24, 2005 | 09:24 PM
vw eater's Avatar
Default b20vtec supercharged...
has anyone done this on here..? and yes i searched.. i was thinking about building a b20b w/gsr head and sticking a jackson racing supercharger on it, how is this?hows the clearence issues in a crx..? thanks
Old Dec 24, 2005 | 09:28 PM
vw eater's Avatar
Default Re: b20vtec supercharged... (vw eater)
i saw a few pic's that lht performance had they did a few swaps w/the samwe combo
This is a fully build LHT B20Vtec, with Endyn pistons, Eagle rods and a fully balanced rotating assembly.
The Supercharger was installed with the LHT 5 rib pulley kit (To avoid slippage) an LHT Custom "S" tube and LHT intercooler. The blower is set to run 9 psi which is spinning 18,500 rpm on a 2.0L motor and last dynoed at 278 whp and 201 tq.
Again with LHT work, the AC is fully functional and this is a true daily driver
Old Dec 25, 2005 | 09:10 AM
dfn_doe's Avatar
hrm, seems like alot of money for only 100 hp.. I'd be curious to see what the torque curve looks like on this one. I pulled 178hp with a stock b20 bottom end and b16a head NA... Seems like if these guys are doing a fully built bottom end AND a supercharger they could have spent that same 4 or 5 grand on just doing a really nice NA all motor build and made similar power without any of the added complexity of the JRSC...
Something like a sleeved b20b bottom end with some 12:1 pistons, balanced bottom end, eagle rods, heavy ported/polished b16a head, big cams, big valves, springs, titanium retainers, maybe some nice ITBs, fuel pump, big rail, big injectors, and a hondata or standalone...
Should rev close to 9 or 9.5 and pull 300ish HP...
But I'm just guessing...
Old Dec 25, 2005 | 12:30 PM
vw eater's Avatar
ya...but 280 is nothing to complain about..i mean in a daily that would be sick...i bet your crv vtec is fun as ****...
Old Dec 26, 2005 | 08:57 AM
vw eater's Avatar
anyone else done this swap?
Old Dec 26, 2005 | 11:33 AM
scUba-stEve's Avatar
Default Re: (vw eater)
you sure that thing is spinning to 18.5k rpm? i kind of doubt it...and if it did, and only made 278whp ...that peak power is probably being carried for about 10k rpms...hahaha.
Old Dec 27, 2005 | 04:43 AM
v4lu3s's Avatar
RTFM
Default Re: (zer0-psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0-psi &raquo;</TD></TR><TR><TD CLASS="quote">you sure that thing is spinning to 18.5k rpm? i kind of doubt it...and if it did, and only made 278whp ...that peak power is probably being carried for about 10k rpms...hahaha.</TD></TR></TABLE>
it is very likely the blower is spinning 18500 rpm as it wont make much power if it was only spinning at 7000rpm.
Old Jan 1, 2006 | 08:01 PM
Honda_RN's Avatar
good luck.. would love to see some pics after you are done with the project!
Old Jan 1, 2006 | 11:20 PM
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">
it is very likely the blower is spinning 18500 rpm as it wont make much power if it was only spinning at 7000rpm.</TD></TR></TABLE>
oh nevermind...i was thinking he meant the motor was spinning to 18,500...hahaha.
Old Jan 1, 2006 | 11:50 PM
SuzukaBlueEh2's Avatar
damn! how reliable has that setup been?
tony413
Mar 15, 2007 10:49 AM
integraftw98
Nov 13, 2006 01:10 AM
275Performance
Nov 26, 2002 10:03 AM
Paste
Sep 13, 2002 02:45 PM
InfamousRS
Dec 20, 2001 09:23 AM
