B20b Swap help please!
Old Sep 7, 2006 | 05:29 PM
B20FERIO's Avatar
Default B20b Swap help please!
Well i am about to do a B20b swap into my 98 civic lx and I need to know a couple of things to make sure I am on the right track.... Can I use a P75 OBD2 ecu, LS OBD2 wiring harness, and a OBD2 LS distributor to make this swap work? Please help me!
Old Sep 7, 2006 | 05:52 PM
unknown0001's Avatar
Default Re: B20b Swap help please! (B20FERIO)
To answer your questions.
-Yes you can run the P75 OBD2 Integra ECU
But if your 98 Civic LX is already OBD 2, why are you using the LS obd2 harness? I don't even think you would need it as it's the same 'OBD Type'
About the OBD 2 distributor...you can use it just fine
Old Sep 7, 2006 | 06:00 PM
B20FERIO's Avatar
Default Re: B20b Swap help please! (Mr.RHTuner)
Thanks alot i just wasnt about the harness because i have read so many differnt things about it.
Old Sep 7, 2006 | 06:38 PM
ek_chris's Avatar
you can actually use your stock harness if you feel like wiring in a new alt clip and IACV.. but if not the ls harness is cool
Old Sep 8, 2006 | 11:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20FERIO &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot i just wasnt about the harness because i have read so many differnt things about it.</TD></TR></TABLE>
well lets jus say my car is a obd-1 civic that had a d16z6 and I pulled it out and installed a obd-1 integra b18b and it was a direct swap.
Only thing I had to do with the wiring was extend the wires for the o2 sensor but that's it
92CivicSiOEM
Dec 17, 2009 05:49 AM
esean93
15
Sep 13, 2008 05:36 PM
4thgenlude
13
Oct 24, 2006 10:46 AM
SpoonyGSR
Jan 28, 2004 03:11 AM
HondaCutter
Sep 19, 2002 01:10 PM
