B20Z SWAP PARTS LIST!! is this everything??
Been researching this swap and have came up with this list.I need confirmation as to if it is correct or not,what can be excluded and what needs to be included.In the list when i refer to the Civic VTI it is the same parts as the Civic SIR/SI etc.
B20Z SWAP PARTS LIST into my 96 civic dx
B20Z Engine
Wiring Harness
CR-V Alternator (Including Mounting Bolts)
94-00 Integra LS Starter Motor (Inlcuding Mounting Bolts)
96-00 Integra LS Intake/Induction/CAI
96-00 Integra LS Intake Manifold (Get New Gasket)
96-00 Integra LS Throttle Body
96-00 Integra LS Injectors
96-00 Integra LS Fuel Rail
96-00 Integra LS Fuel Pressure Regulators
96-00 Integra LS Throttle/Accelerator Cable
96-00 Integra LS IAT Sensor
96-00 Integra LS EVAP Purge Solenoid
94-00 Integra Exhaust Manifold (Get New Gasket)
96-00 Integra LS P75 ECU ODBII (If ODBI I Will Need ODBII - ODB1 Conversion Harness)
Mounts
96-00 Civic VTI B16A Rear Mount Bracket
94-00 Integra LS/GSR/ITR Front Transmission Mount Bracket
CR-V/CRX 92-97 VTI Drivers Side Front Lower Engine Mount Bracket
CR-V Timing Belt Mount Bracket
Gearbox/Transmission
96-00 Civic VTI B16A Gearbox (Including Clutch Fork/Clutch Fork Pivot Bolt/Clutch Fork Release Spring)
B16A Clutch/Pressure Plate
B16A Flywheel
96-00 Civic VTI B16A Shift Linkage (Including Mounting Bolt/Washers/Bushings)
Misc/Other
96-00 Civic VTI B16A Axles
96-00 Civic VTI B16A Radiator
96-00 Civic VTI B16A Exhaust System
CR-V Timing Belt
New Honda Oil Filter
New Honda Fuel Filter
Honda Manual Transmission Fluid (3 bottles)
New Spark Plugs
Magnecor Wires
Questions
1) From initial searches on ebay,i can only find aftermarket parts on some of the listed items such as throttle bodies and intake manifolds,fuel rails,does this matter?
2) What exhaust system should i be using? Will one from a B16A VTI work with the B20Z?
3) Will a B16A exhaust manifold (Header) work with this swap?
4) Does the B-Series tranny have to be hydro? If so,is it a direct bolt in?
5) If i bought a B16A tranny, normally will it come with flywheel,pressure plate,clutch fork,clutch fork pivot bolt,clutch fork release spring?
6) Would it be cheaper to buy a new complete B-Series mount kit such as Enjo instead of piecing together different mounts?or should i use the stock mounts and get the rear "t" brackets??
B20Z Engine
Wiring Harness
Mounts
B16A Flywheel
Misc/Other
CR-V Timing Belt
New Spark Plugs
Magnecor Wires
Questions
Hondarookie93
25
11-03-2010 05:52 PM
AGENT 99
04-13-2008 09:37 PM
LSVTEC96HB
11-17-2002 02:33 PM
