b20 swap wont start!
i just got finished with my b20 swap into a 98 hatch, all ready to turn that key and hear that beast start up but no such luck.......all harnesses are in and everything, everything is hooked up but i cant hear the fuel pump turn on. i checked the fuel pump fuse but still no luck......any ideas???
yea i checked all grounds, we were thinking that it was a bad ecu so we swapped the ecu......our next solution was that the piggy we made for the obd-2 to obd-1 was incorrect however, we plugged in a pre made one and that didn't work. i am running a pr4 obd-1 ecu......wonder what the problem could be??
hey guys i appreciate your efforts to help me out, well finally after more frustration and hair pulling i decided to have a shop take a look at it. its running and everything now and the problem was some small wiring problems. its up and running though and all i need is to get the exhaust welded and this bad boy will be on the road
@eeekthehatch is possible if you tell me what exactly was wrong in the wiring.
please and thanks
please and thanks
please and thanks
please and thanks
