LS engine into EG hatch
Old Aug 6, 2002 | 09:18 PM
Dokta's Avatar
Default LS engine into EG hatch
I have a 99 Integra LS engine that I wanted to put into my 93 civic Si. I wanted to stay OBD1.
Would I use the OBD2 wiring harness on the 99 LS engine with an OBD1 LS ECU?
Or do I need to get an OBD1 LS wiring harness if I use an OBD1 LS ECU?
Old Aug 6, 2002 | 09:30 PM
JV's Avatar
JV
Who?
Default Re: LS engine into EG hatch (Dokta)
The OBDII wiring harness will plug right into the underhood harnesses....
Same as my swap. OBDII 96 LS motor with OBDI P75 ECU. It was plug and play...
Old Aug 6, 2002 | 09:40 PM
Dokta's Avatar
Default Re: LS engine into EG hatch (JV)
Thank you. That was easier than I thought.
Enjoibaker
Sep 5, 2011 10:00 PM
eggsi619
May 4, 2009 03:12 PM
suprajb
May 6, 2003 04:07 AM
wickedxboi
Dec 10, 2002 10:03 PM
