B18C-R axle problem
I have a 99 model JDM B18C 98 spec R motor, and it came with 36 mm axles. I know i need either 5 lug ($1300) or an axle that will fit. My question is: will 94+ GSR or 99-00 Si axles work and how much are they? I have the complete type R changeover, which means i'll be using the 99 type R halfshaft.
Re: B18C-R axle problem (JDMspecEJ8)
Yes. 99-00 Civic Si or 94-01 Integra axles will fit into your hubs being a 32 mm hub.
Not sure on how much they are, I would talk with Honda themsevles for a new set. And about the half shaft. I'm not too sure the differences between the B18C-R and the US spec B series. I am pretty sure they are the same, however. |
Re: B18C-R axle problem (poison)
does every b18c-r have 36mm?
Re: B18C-R axle problem (yayaRl337)
I'm interested in the answer also. Anyone ever run across a table or spec sheet matching models with this specification (axle size?). Thx, Mark |
