b18c
Old Jun 25, 2005 | 08:20 PM
jonu's Avatar
Default b18c
I was thinking abouy buying a jdm integra type-r motor. I saw one for sale, on the block it has b18c ingraved, is this a type-r?
Old Jun 25, 2005 | 08:29 PM
Earthworm Jim's Avatar
Default Re: b18c (jonu)
The motor should say "B18C5" on the block. If not, I don't think it's a Type-R motor. I might be from Japan though.
Old Jun 25, 2005 | 08:41 PM
jonu's Avatar
Default Re: b18c (TheGeneral)
its suppose to be jdm, it has the lsd tranny and over sized intake and exhaust manifolds, red valve cover that appears to have never been removed
Old Jun 25, 2005 | 08:44 PM
PnkRokCountryboy's Avatar
a JDM B18C is the Japanese GSR motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonu &raquo;</TD></TR><TR><TD CLASS="quote">its suppose to be jdm, it has the lsd tranny and over sized intake and exhaust manifolds, red valve cover that appears to have never been removed</TD></TR></TABLE>
That doesn't mean anything. Just because you put a read valve on something doesn't make it JDM. A B18C is a Vtec motor (I believe). I have an ITR motor, the block should read B18C5 and then the code underneath it.
Old Jun 25, 2005 | 08:59 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonu &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking abouy buying a jdm integra type-r motor. I saw one for sale, on the block it has b18c ingraved, is this a type-r?</TD></TR></TABLE>
B18C can either be a Type-R or SiR-G motor. Looking for the red valve cover, if it hasn't been changed. Also, look at the intake manifold. Snail-like = SiR-G, Skunk2-like (well, they designed it after the ITR manifold) = Type-R. Also, the head cast numbers. P72 = SiR-G, and PR3-x = Type-R.
Old Jun 25, 2005 | 09:01 PM
wowowee's Avatar
Default Re: b18c (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">B18C can either be a Type-R or SiR-G motor. Looking for the red valve cover, if it hasn't been changed. Also, look at the intake manifold. Snail-like = SiR-G, Skunk2-like (well, they designed it after the ITR manifold) = Type-R. Also, the head cast numbers. P72 = SiR-G, and PR3-x = Type-R.</TD></TR></TABLE>
Thanks for the information man.
Didn't know about the different intake manifolds and the head cast numbers.
Old Jun 25, 2005 | 09:04 PM
knockout's Avatar
Default Re: b18c (PnkRokCountryboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnkRokCountryboy &raquo;</TD></TR><TR><TD CLASS="quote">a JDM B18C is the Japanese GSR motor</TD></TR></TABLE>
well, youre half right. Japanese integra motors dont have the 5th digit. the JDM B18C could be either GSR or Type R.
Old Jun 25, 2005 | 09:12 PM
jonu2's Avatar
Default Re: b18c (knockout)
so how can i find out wether its a gsr or it-r? did gsr come with lsd?
Old Jun 25, 2005 | 09:16 PM
wowowee's Avatar
Default Re: b18c (jonu2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonu2 &raquo;</TD></TR><TR><TD CLASS="quote">so how can i find out wether its a gsr or it-r? did gsr come with lsd?</TD></TR></TABLE>
Also, not sure on the GSR having an LSD tranny, but I think it does.
Old Jun 25, 2005 | 09:17 PM
A.E Motoring's Avatar
Default Re: b18c (EM1 y0)
he just told you...look at the cast numbers..if its a type r it will say pr3
Old Jun 25, 2005 | 09:18 PM
jonu2's Avatar
what does the sir-g rate for power
Old Jun 25, 2005 | 09:19 PM
jonu2's Avatar
the only cast numbers i saw were b18c and lsd
Old Jun 25, 2005 | 09:26 PM
there on the head
Old Jun 25, 2005 | 09:40 PM
Stoich EG2's Avatar
Default Re: b18c (SPNFEDEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonu2 &raquo;</TD></TR><TR><TD CLASS="quote">what does the sir-g rate for power</TD></TR></TABLE>
C'mon, that's basic knowledge to just search for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonu2 &raquo;</TD></TR><TR><TD CLASS="quote">the only cast numbers i saw were b18c and lsd</TD></TR></TABLE>
Did you not read what someone posted for you before? if not, here it is again:
Thank God your 5 posts for the day are over. While you're waiting for tomorrow to express what's running through your tiny mind, i suggest you read the rules and FAQ/Stickies!
https://honda-tech.com/zerothread?id=990205
https://honda-tech.com/zerothread?id=878010
and last but not least, the most important:
https://honda-tech.com/zerosearch
Old Jun 25, 2005 | 09:43 PM
HATCHingMN's Avatar
yes, that's a JDM ITR motor and tranny
Old Jun 25, 2005 | 11:44 PM
Default Re: b18c (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 &raquo;</TD></TR><TR><TD CLASS="quote">
blackoutvtec845
May 9, 2010 11:11 AM
Deo
May 3, 2009 02:02 PM
xschwinn24
28
Jul 1, 2006 03:32 PM
10kracer
17
Jun 24, 2006 12:22 PM
jonu
Jun 25, 2005 11:19 PM
