B18b into a EJ??
Old Jun 8, 2006 | 10:31 PM
hyperspoon's Avatar
Default B18b into a EJ??
What ecu will i need and how will i do the wiring?
Old Jun 8, 2006 | 10:37 PM
RedHB..D15B's Avatar
Default Re: B18b into a EJ?? (hyperspoon)
your first post and its allready a dumb one....u can use a LS ecu..search is your best of friends.
Old Jun 8, 2006 | 10:38 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: B18b into a EJ?? (RedHB..D15B)
There is no wiring. Plug and play if you use an OBD1 engine.
Old Jun 8, 2006 | 10:42 PM
hyperspoon's Avatar
Default Re: B18b into a EJ?? (JDM_Ej)
its an obd2 motor
Old Jun 8, 2006 | 10:55 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyperspoon &raquo;</TD></TR><TR><TD CLASS="quote">its an obd2 motor</TD></TR></TABLE>
Get an OBD1 distributor and injectors. Use the wire harness off your stock engine, and get an OBD1 LS ECU.
Old Jun 8, 2006 | 11:19 PM
SIRIUS EJ8's Avatar
Pretty Much, LS ECU of course, not much of a difficult task to do.
Old Jun 8, 2006 | 11:21 PM
hyperspoon's Avatar
my Engine is a Obd2b motor tho off a 99 civic EX in my 97 civic EX
I didn't Mention that will i still need the same things?
Old Jun 8, 2006 | 11:54 PM
hyperspoon's Avatar
Old Jun 9, 2006 | 01:57 AM
fmrprojects's Avatar
you need a abd-2a LS ecu from the 96-98 LS. everything else just leave the same
Old Jun 9, 2006 | 02:25 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyperspoon &raquo;</TD></TR><TR><TD CLASS="quote">my Engine is a Obd2b motor tho off a 99 civic EX in my 97 civic EX
I didn't Mention that will i still need the same things?</TD></TR></TABLE>
ert?
99 EX wasn't a B18b... ??
Old Jun 9, 2006 | 06:59 AM
Slopoke's Avatar
Default Re: B18b into a EJ?? (Syndacate)
Im pretty sure he meant it was previously in a '99 ex.
He needs an obd2A ecu. He needs to reuse his '97 harness and adapt it to the b18b.
Old Jun 9, 2006 | 08:12 AM
hyperspoon's Avatar
Default Re: B18b into a EJ?? (Slopoke)
damn so im gonna have to find the original harness that came off of a 97 ex coupe? And adapt it...any good sites that explain how i can do this???
Old Jun 9, 2006 | 01:23 PM
Slopoke's Avatar
What about the harness is your car right now?
Simply reuse that. Change the distributor, alternator, and injector plugs to obd1 plugs. Thats all you need to do.
Old Jun 11, 2006 | 06:07 PM
hyperspoon's Avatar
alright kool
EKtypeRhaTcH
May 10, 2005 10:46 AM
974drgs
Jan 27, 2005 05:45 AM
kholmes
Aug 28, 2003 06:40 AM
drewlee
Jan 6, 2003 01:53 PM
Patron
Jan 2, 2002 02:43 PM
