B18 swap question...
I'm swapping a B18B into my EG and i'm wondering if i could use the civic throttle cable without getting the integra one..Has anyone ever done this before? Any advice would be appreciated..Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5lugcivic »</TD></TR><TR><TD CLASS="quote">everything should just fit right in... why wouldnt the LS bracket fit?</TD></TR></TABLE>
everything does fit..but the Civic throttle cable is about 1-2 inches shorter
Have you swapped the motor yet? It doesn't sound like it. Is it a c5 or a c1 motor? If it is the c5, then I don't know why it wouldn't since I have a skunk2 im and my cable worked fine. The motor orientations are the same (they are not any wider than mine and they sit at the same angle), so if it is the c5 then it should fit just fine.
-Shane
-Shane
The motor is a B18B1...It's put in and everything is plugged up...Just that the bracket on the motor sits too far to the driver side...So with the Civic throttle cable; it won't reach the throttle body....It's about 1-2 inches short of the throttle body..
esean93
10
Nov 8, 2008 02:52 PM
