B16A swap into 92 civic si/ex
Old 05-06-2002, 04:05 PM
under_psi's Avatar
Default B16A swap into 92 civic si/ex
2nd gen JDM B16A (OBD1) into a 93 civic si/ex (stock motor is D16Z6, sohc vtec)
if I'm using a mugen chipped P28 would it simply be plug and play? or is there any wiring involved?
also, the mugen chipped P28 disables the knock sensor...is it OK to just remove the knock sensor from the block?
thanks
Old 05-06-2002, 04:21 PM
Kamin's Avatar
Default Re: B16A swap into 92 civic si/ex (T.O.tegs)
you wont need to wire a thing
if the knock sensor is disabled you should leave it on the block because it just runs into the harness and dosent go to the ecu.
Old 05-06-2002, 04:38 PM
under_psi's Avatar
Default Re: B16A swap into 92 civic si/ex (KAMiN)
thanks, just checking before getting started
94EJ1Coupe
12
03-16-2008 10:10 AM
h2point2
05-06-2007 09:03 PM
93(Civic)EG6
09-26-2006 03:17 PM
93(Civic)EG6
09-18-2006 11:21 AM
HondaVTEC93
22
03-09-2005 10:57 PM
Quick Reply: B16A swap into 92 civic si/ex
