B16A swap into 92 civic si/ex
2nd gen JDM B16A (OBD1) into a 93 civic si/ex (stock motor is D16Z6, sohc vtec)
if I'm using a mugen chipped P28 would it simply be plug and play? or is there any wiring involved? also, the mugen chipped P28 disables the knock sensor...is it OK to just remove the knock sensor from the block? thanks http://images.zeroforum.com/smile/embeer.gif |
Re: B16A swap into 92 civic si/ex (T.O.tegs)
you wont need to wire a thing http://images.zeroforum.com/smile/emsmile.gif
if the knock sensor is disabled you should leave it on the block because it just runs into the harness and dosent go to the ecu. |
Re: B16A swap into 92 civic si/ex (KAMiN)
http://images.zeroforum.com/smile/emthup.gif thanks, just checking before getting started http://images.zeroforum.com/smile/embeer.gif
