b16 cel 23 (knock sensor)
Old Feb 9, 2006 | 02:24 PM
B16'D DA9's Avatar
Default b16 cel 23 (knock sensor)
I am getting a cel 23 in my 92 b16 teg. But the cel doesnt come on until about 4-5mns of driving it easy, but if I drive it harder it comes on faster, I assume thats because thats when it detects detonation and throws the code, right? Now my question is lately when I come to a stoplight the car will surge about 200rpms about 3-4 times then stop, it only does it as Im stopping (neutral, or clutch engaged). I just soldered the wire for the KS cause it never was, it was only twisted (also how important is it for this wire to be insulated like the o2?) then reset the ecu and drove, but after a few its back again! Now my question is would the cel delay like this if it was unplugged too?
Also when I check my cel's I get codes 23 AND my "normal" 20. Thats been there since day 1 of my swap (I was told it wont go away but doesnt do anything) How come that code doesnt show when I first start the car? is it hidden? Or is the KS's code hidden untill the cel's are pulled? Anyone with experience and/or knowledge please chime in.... Thanks in Advance.
Old Feb 9, 2006 | 05:55 PM
B16'D DA9's Avatar
Oh and yes vtec works...Why?
Old Feb 9, 2006 | 08:28 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (B16'D DA9)
check to see if the knock sensor is tight in the block , then check the continuity from ecu to knock sensor , lastly replace the knock sensor ...hint the cel 23 does not come on when the sensor reads pinging or knocking it just tells the ecu to pull timing out it ony throws the code when there is something wrong with the wiring or the sensor(usually)
Old Feb 11, 2006 | 08:23 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (HOOKUPS)
My friends CRX B16A had the same problem. The knock sensor wasn't completely tightened down to spec. After we did that it went away.
Old Feb 11, 2006 | 11:23 AM
CP9A6M's Avatar
Default Re: (HondaPartsHero)
What is the spec on that anyways?
Old Feb 13, 2006 | 10:25 AM
DYNO-PRO
Default Re: (CP9A6M)
hand tight , then a 1/4 turn lol
Old Feb 13, 2006 | 04:24 PM
B16'D DA9's Avatar
fixed traced it to a missed wire,it was in d6 instead of d3...stupid me!
Old Feb 13, 2006 | 05:01 PM
ExCon's Avatar
does anyone have a pic of the knoc scensor, i have the same exact code and i couldnt find it when i was lookin for it. pic would really help, thnx
Old Feb 13, 2006 | 05:05 PM
ExCon's Avatar
Default Re: (JDMedEK)
is this it. does anyone have a pic of it on the block
Old Feb 13, 2006 | 05:18 PM
CP9A6M's Avatar
That's actually an o2 sensor. This is a knock sensor:
Old Feb 26, 2006 | 09:46 PM
Slow_import's Avatar
i am having this same problem but in my 00 si converted to obd1 runing a jdm p30....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16’D DA9 &raquo;</TD></TR><TR><TD CLASS="quote"> I am getting a cel 23 in my 92 b16 teg. But the cel doesnt come on until about 4-5mns of driving it easy, but if I drive it harder it comes on faster, I assume thats because thats when it detects detonation and throws the code, right? Now my question is lately when I come to a stoplight the car will surge about 200rpms about 3-4 times then stop, it only does it as Im stopping (neutral, or clutch engaged). I just soldered the wire for the KS cause it never was, it was only twisted (also how important is it for this wire to be insulated like the o2?) then reset the ecu and drove, but after a few its back again! Now my question is would the cel delay like this if it was unplugged too?
Also when I check my cel's I get codes 23 AND my "normal" 20. Thats been there since day 1 of my swap (I was told it wont go away but doesnt do anything) How come that code doesnt show when I first start the car? is it hidden? Or is the KS's code hidden untill the cel's are pulled? Anyone with experience and/or knowledge please chime in.... Thanks in Advance.</TD></TR></TABLE>
are you running a jdm ecu too....
Old Apr 5, 2006 | 03:46 PM
standinghollow's Avatar
Default Re: (Slow_import)
dont mean to jack.I just swapped a jdm gsr in to my 94 ls obd-1.The knock sensor got broken.I bought a brand new one from honda ran it to D3.No Cel for 4 days.Now the damn code 23 came up like 2-3 times on me today.Only comes on once in a while and I dont know why.Its a Jdm p72 ecu too.About to give up on my swap.
Old Apr 6, 2006 | 06:51 PM
egsleepercivic's Avatar
ihad this issue in my 94 ex with a b16(jdm) swap. it was my wiring, re did the wiring the issue has not returned. check your connections ..............good luck
Old Apr 12, 2006 | 01:25 PM
ocks's Avatar
Default Re: b16 cel 23 (B16'D DA9)
I'm having this same problem but I don't know where or how to check if my wiring is correct. Is there a diagram or photos I could follow to make sure my setup is right?
Old Apr 14, 2006 | 09:39 AM
ocks's Avatar
Default Re: b16 cel 23 (ocks)
ttt
Old Apr 14, 2006 | 03:46 PM
ocks's Avatar
bump for anyone who may know
Old Apr 15, 2006 | 02:12 PM
ocks's Avatar
ttt
Old Apr 16, 2006 | 02:00 PM
Technical Hero
Old Aug 26, 2009 | 01:55 AM
rquint07x's Avatar
Default Re: b16 cel 23 (knock sensor)
hello I'm a new member of HONDA TECH, now my question is: i have a B16A JDM, with P30 ECU, my knock sensor got broken, but is disable con the ECU, so the cel 23 does not appears anymore. This could cause a huge problem on the engine or this could affect the power of the engine if this knock sensor is disable on the ECU???
Thanks in advance!!!!!!!
Old Jun 17, 2016 | 11:41 PM
f22b2's Avatar
Hi guys I have a 90 integra with the b16a on it I buy like that but I have one issue
After 4,000 rpm my check engine light get on I replace the knock sensor but its still showing the same code on the ecu code 23 and I find out the oxygen sensor go on the catalytic converter its not connect last onwer cut the wire
Its that can be the problem or ecu because
The knock sensor wire are good
mitchh29
Jan 23, 2014 09:31 PM
88 EF Hatch
Sep 12, 2009 09:45 PM
impact_blu
Dec 29, 2005 03:52 PM
