B16 Axles, and intermediate shaft which works?
Old 11-24-2001, 08:22 AM
DragII's Avatar
Default B16 Axles, and intermediate shaft which works?
I have heard that GSR axles will work,
and I have read that the GSR intermediate shaft is too large for the B16 tranny,
So which is correct?
can I use a B16 intermediate shaft, and teg axles?
Old 11-24-2001, 09:42 AM
internet ay's Avatar
Default Re: B16 Axles, and intermediate shaft which works? (DragIIcivic)
i have a jdm b16 and i got a 90-93 integra intermediate shaft from a manual trans on mine because when i got the motor it didnt come with one. it bolts right up . if you are talking about a delsol motor or a civic si im not sure if they are the same. hope this was a help
Old 11-24-2001, 02:52 PM
DragII's Avatar
Default Re: B16 Axles, and intermediate shaft which works? (internet ay)
It's a del sol motor, but yeah they should be the same. so it should work for me too.
which axles did you use w/ that shaft?
Old 11-24-2001, 11:24 PM
i bought mine from RAXLES which are premade hybrid axles which i beleive are 90-93 integra inner joints and 1st gen integra outer shafts this is in a crx with the hasport b series motor mount kit.
Old 11-25-2001, 06:33 AM
DragII's Avatar
ahhh, gotcha....thats why.
Old 11-25-2001, 08:27 AM
fowler!'s Avatar
You know that the intermediate shaft from a 90-93 (whatever he used) won't work with your application...he has a cable tranny while you will need to use a hybro...both have different intermediate shafts..
[Modified by fowler, 5:27 PM 11/25/2001]
Old 11-25-2001, 08:37 AM
DragII's Avatar
Default Re: B16 Axles, and intermediate shaft which works? (fowler)
yeah, I'm gonna need the SI, or Del Sol Intermediate shaft, but I wanna know if i can use GSR axles with the Del Sol shaft.
Old 11-25-2001, 10:23 AM
Jackson's Avatar
yes, gsr will work fine.
Kusai.Nihonjin.Desu
13
06-23-2009 05:45 PM
Rob!
06-06-2003 11:47 AM
BoostedsiR
03-19-2003 07:01 AM
XANDER-666
10-07-2002 12:04 PM
juicy.koreans.suck
10
01-10-2002 10:47 AM
Quick Reply: B16 Axles, and intermediate shaft which works?
