gsr swap help
Re: gsr swap help
If you don't want to cut the wire harness, then you should get a 99-00 Civic SI or Ex engine harness. Then you will have to buy an obd2b Distributor, injectors, and an alternator and replace it with your 94 gsr parts. Then you need to get a conversion harness for the ecu if you plan on using a obd1 ecu. So find obd2b====>obd1 conversion harness.
Re: gsr swap help
If you live in California and plan to get BARD then swapping everything over to OBD2B would be a could idea. If not then just get a conversion with a ECU to match the engine.
