another no spark thread..
97 civic lx..94 b16..obd1 dizzy rewired to work on obd2 harness....cant seem to get any spark..i hear the fuel pump when i turn on the ignition.....ive done cap and rotors..plugs..plug wires...checked coil and icm and still no idea....any suggestions...please helpppppppppppppp......
what should a person check if they're not getting spark..please list all things i should check....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiftee_su »</TD></TR><TR><TD CLASS="quote">what should a person check if they're not getting spark..please list all things i should check....</TD></TR></TABLE>
Your wiring at the distributor
i was told to just mtch the colors up..all the wires were the same color so i think its good and firing order would still give it spark wouldnt it??it would just run a lil sloppy but still have spark correct??im pretty sure its correct though...anyone help please ....thanx all
main relay is located in the fuse box under the hoood right??if not right please tell me where it is located..thanx to all that has tried to help....
