another dumb question....
Old Aug 4, 2003 | 07:28 PM
tbocrx's Avatar
Default another dumb question....
i know its dumb...but i searched already and cant find it.....for example...when swapping in a b16 into a cx hatch....i add knock sensor to pin location d3...but....what do i do with the wire that is already in that location....not just on the knock sensor but on all the wires....a4, d6, d3, a20.....someone please help me....also need info on how to take the pins out of the ecu plugs and off or misc. wires....? thyanks
Old Aug 4, 2003 | 07:49 PM
poison's Avatar
Default Re: another dumb question.... (tbocrx)
what year/model civic do you have? if you have a VX, there will be a wire at D3 already and just need to put the D3 wire to the knock sensor.
To take out pins, you use a very small screw driver and they slide right out.
Old Aug 4, 2003 | 08:25 PM
tbocrx's Avatar
im really asking this question in general...not model specific...i dont understand what to do when doing wiring changes what to do with the wires that are already in the locations i need to add wires to....im about to do a b18c5 into a 94 ls and when i went to add the vtec and knock wires there are already wires in those pinouts....should i take those wires out or leave them....if the wire already exists...how do i do it....like you sdaid...there is already a d3 wire on the vx so how do i hook up the knock sensor....sorry for this question...im just a little slow....
Old Aug 4, 2003 | 08:43 PM
poison's Avatar
Default Re: (tbocrx)
well it depends on the ECU, what obd type deal. You need to assign pinouts to different sensors and such according to what the ECU looks for.
For instance, on the VX with the factory ECU and factory motor, the D3 pinout, the factory ECU uses that specific pinout for one of the Heated O2 sensor (5 wire O2 sensor).
When using for instance, a B16 P30 ECU, the P30 ECU uses D3 for the knock sensor. So you have to change the wire and lead it to the knock sensor so the ECU knows it's there.
As for VTEC, if the wires are there, then you just lead them to the associated pinout so it's a complete circuit to that specific sensor to that specific pinout.
Like VTEC solenoid to the A4 pinout and such.
Make sense?
Chimera
12
Dec 24, 2018 03:14 PM
riceburnerryan
May 22, 2008 08:51 AM
89sib16
Dec 24, 2003 10:07 PM
98AccordEX
Sep 1, 2003 02:27 PM
takeheed
Sep 3, 2002 12:30 PM
