AC in h22 ek
Old Apr 2, 2009 | 03:13 AM
hondasport2000's Avatar
Default AC in h22 ek
Hey guys,
Just wondering if there is a way that i can fit/run AC on my h22 ek civic?
I have all the AC gear from when we did my swap from the d16y7, along with the compressor from the h22.
Any info is appreciated.
Thanks
Old Apr 2, 2009 | 11:27 PM
TheCheeseWedge's Avatar
Default Re: AC in h22 ek
i would also like to know but in an eg?
Old Apr 3, 2009 | 02:36 AM
I have only ever seen a few ek's with AC....and not sure if i've seen any in an eg.
The EK's ive seen were here, so i am hoping someone will be able to help.
Old Apr 4, 2009 | 01:56 PM
My searches have come up empty....anyone able to help me out?
Old Apr 4, 2009 | 07:09 PM
nikko_SOHC's Avatar
call innovativemounts and talk to brian. he can help you. he made me a bracket that fit an h series but used a d series compressor.
Old Apr 5, 2009 | 08:35 AM
Thank a lot for the info Nikko.
I have just emailed them and am waiting to hear back.
Sounds like this mount may be just the ticket..
http://www.innovativemounts.com/Prod...ductCode=50080
Old Apr 7, 2009 | 11:21 AM
per4mance's Avatar
I ran AC and PS in my Si coupe. All needed is a mounting bracket for the h22 that uses the factory compressor on the car. Its a vey simple setup. Make a flat plate that mounts to the 4 holes on the h series were the compressor goes. The weld on 4 tabs to hold the compressor inline with the alternator. Its really easy.
Old Apr 13, 2009 | 09:45 AM
Boosthead's Avatar
HCP engineering used to make one. Not sure if they are in business still. Can't seem to find their website.
Old Apr 14, 2009 | 07:00 AM
hondaZvic's Avatar
I used to have ac hooked up with my h22 ek.. I actually used the oem bracket and h22 compressor. But what I did was took my bracket to a machine shop and they shaved off the back half for me... thinned it up by about 1/2 in.. Was pretty tight fit, but I got it all to work.
Old Apr 15, 2009 | 08:15 AM
Pm sent
Just to be clear...you had the machine shop shave some of the part that mounts to the motor correct? Any chance you have a picture to show fitment?
As for the HCP mount, that would be close to $250 by the time it got to my door (canadian dollar and shipping ) which is more than i am able to spend.
Thanks for all the replies guys, i really appreciate it.
Old Apr 15, 2009 | 08:36 AM
hondaZvic's Avatar
I dunno if I have a pic... ill check later tnight. But basically I took my oem compressor-to-block mount/bracket (was a flat kinda bracket)and I just had them shave off the back half of it.. So that the compressor was closer to the motor.. And it was only 1/2 inch at most I believe.. Then I had to grind just a little bit off the frame rail so the compressor pulley could spin.
Old Apr 17, 2009 | 03:32 PM
92civlude's Avatar
You have to use the H22 AC bracket and make spacers to line up the civic compressor pulley. You also must use a 03 CRV AC pulley (its a 6 rib). You also need to cut the end of alternator adjustment bracket, otherwise it will hit the compressor. The AC lines also have to be manipulated away from the condenser. And the fan will have to be relocated to the front of the condenser. You must use a "pusher" fan. Make sure the fan is wired to push air into the condenser.
b18tegg
Oct 29, 2006 03:14 PM
eg6madness
May 5, 2006 06:02 AM
nikolai.
Feb 28, 2006 02:04 PM
DualCamEK
Jul 22, 2005 08:46 AM
