what engine swap to do
I am planning on doing an engine swap I want a fast car for the 1/4 mile I dont care all that much about top speed, I am problably going to spend about 2000 from the start just for the base engine to build on what should i go with, any opinions would be great
thanks
thanks
Re: what engine swap to do (shortyz)
If you are going to go through all the expense of buying a mount kit anyway, qhy not do a B20 rather than a B18A1? I guarantee you that if you rode in both, you would find that the B20 is worth every penny over the B18A1.
Re: what engine swap to do (Bryson)
what swap is more reliable and less costly and will still do good with the 1/4 mi time? in other words how can i hit 12's and still have a reliable engine car and also a daily driver?
Re: what engine swap to do (burnett999)
sohc vtec motor=$400 depending on where you live but it should be cheap then a turbo kit im not sure what you would go for but after everything is done you might run high 13s depending on your setup
Re: what engine swap to do (big pete)
i would say that b16a is not your best quarter mile performer, depends what car you have but your probably looking at mid 14's from a civic/crx. the b18a can be just as quick (i've seen it) but thats a whole other debate.
a b20 would have great torque, if you can find one for a good price. an ls/vtec or b20/vtec is what your gonna need to run 12's n/a imo.
as.dhflasyhgdfkiauwsyelrfijhs,kdhbjzhsgdflasywejkr fhaksjdfjshIwishpeoplewouldusethesearchbutton !!!skjdfkjashdjfhgasldhgflshdfljhsdjfhsd
