CFK sensor
Old Nov 28, 2007 | 10:14 AM
Fat Chick Magnet's Avatar
Default CFK sensor
No Results Found
Your search for cfk sensor returned no results.
Please try different search criteria or a different data set.
I'm doing a 96 spec JDM ITR swap into my gsr shell and I'm using a obd2a LS engine harness and there is a extra plug hanging which is for the CFK sensor. I need to know if the 96 spec JDM ITR motor has a CFK sensor and where its located. I looked all around the oil pan and didn't find a plug unless i wasn't looking hard enough.
This is what the plug looks like in case anyone is interested.
Old Nov 28, 2007 | 10:20 AM
BlueR's Avatar
Default Re: CFK sensor (Fat Chick Magnet)
the crank sensor is located on the alternator side of the motor
i do not believe that JDM 96 spec motor came with this sensor
Old Nov 28, 2007 | 01:07 PM
Aquafina's Avatar
You'll need to put a US oil pump on it (where the sensor is located), or use the correct JDM ECU for the engine.
Old Nov 28, 2007 | 01:09 PM
mstewar's Avatar
Default Re: (Aquafina)
or wire it up to the distributor (CKP)...?
the reason you couldn't find info on it is because it's CKF..
Old Nov 28, 2007 | 01:19 PM
Aquafina's Avatar
Default Re: (mstewar)
Here is how you bypass ithttp://technet.ff-squad.com/ckftrick.htm
Old Nov 28, 2007 | 02:29 PM
JOHN WAYNE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Here is how you bypass ithttp://technet.ff-squad.com/ckftrick.htm</TD></TR></TABLE>
yep...i did this. works just fine
Old Nov 28, 2007 | 02:46 PM
I'm actually using JDM 96 spec ecu so i think i should be okay if they didn't come with the crank sensor. I just need to wire up vtec and knock sensor am i missing anything else?
dawetnek
Mar 13, 2011 06:43 PM
hondastreet
Mar 17, 2005 06:31 AM
Greasemonkey
Oct 19, 2004 03:22 PM
4DRPIMPIN
15
Apr 23, 2004 05:46 PM
