Differences between ITR 5 lug conversion and CTR 5 lug conversion
Old Nov 21, 2004 | 05:56 PM
Uneekpinoysk8er's Avatar
Default Differences between ITR 5 lug conversion and CTR 5 lug conversion
im currently looking into getting a 5 lug conversion, and theres one for sale locally but its off a CTR. i heard the only difference is the axel size, but aside from that is there any other differences??? does the CTR 5 lug bolt up perfectly to an integra?
Old Nov 21, 2004 | 06:04 PM
migs's Avatar
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (Uneekpinoysk8er)
USDM ITR 5lug = CTR 5lug (32mm hubnut)
JDM ITR 5lug has a bigger hub nut, which is 36mm
Old Nov 21, 2004 | 06:56 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (migs)
Are brakes the same on USDM ITR and CTR?
Old Nov 21, 2004 | 07:00 PM
migs's Avatar
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (sscguy)
Yes.
Old Nov 21, 2004 | 07:58 PM
esponet's Avatar
if any, the front knuckle will be different,
defenetlly the front brake lines are different.
i have used jdm itr on civic before with no problems, so i assume you can do the opsite, just have to change the front brake lines to itr.
Old Nov 21, 2004 | 08:01 PM
eg6sir-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">USDM ITR 5lug = CTR 5lug (32mm hubnut)
JDM ITR 5lug has a bigger hub nut, which is 36mm</TD></TR></TABLE>
jdm itr 5lug will only work with the 36mm axles without it, well its pita.
Old Dec 25, 2004 | 11:09 AM
XX Boosted Si XX's Avatar
im gonna bump this topic cause I wanna be sure......I have a 00 EM1 with CTR 5-lug swap. I just ordered new brakes and pads from a 2001 ITR (USDM). Everything should be the same size correct?
Old Dec 25, 2004 | 11:35 AM
Haleiwa-Brando's Avatar
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (XX Boosted Si XX)
Keep in mind that going from four to five lug is going to significantly lower your options of wheel choices. Post pics of the install.
Mele Kalikimaka,
Brandon
Old Dec 25, 2004 | 12:38 PM
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (Haleiwa-Brando)
im jus waiting for spring to put on my 5-lug works on
http://memimage.cardomain.net/...l.jpg
Old Dec 25, 2004 | 04:55 PM
diM.'s Avatar
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s &raquo;</TD></TR><TR><TD CLASS="quote">
jdm itr 5lug will only work with the 36mm axles without it, well its pita.</TD></TR></TABLE>
so true.. getin 36mm axles or mating them with other parts was a bitch to do
Old Dec 25, 2004 | 06:02 PM
CTRbOy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XX Boosted Si XX &raquo;</TD></TR><TR><TD CLASS="quote">im gonna bump this topic cause I wanna be sure......I have a 00 EM1 with CTR 5-lug swap. I just ordered new brakes and pads from a 2001 ITR (USDM). Everything should be the same size correct?</TD></TR></TABLE>
i have CTR 5lug conversion on my em1,yes its the same as usdm itr. and btw...your car looks alot like mine but in black...5lug all the way!!!
https://honda-tech.com/zerothread?id=1058173
Old Dec 25, 2004 | 06:14 PM
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (itrboy)
that ebp em1 looks sick im waitng for my trunklid im going wingless soon
Old Dec 25, 2004 | 06:34 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind that going from four to five lug is going to significantly lower your options of wheel choices. </TD></TR></TABLE>
And adds almost 50 lbs of unsprung weight......
Old Dec 25, 2004 | 06:39 PM
CTRbOy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XX Boosted Si XX &raquo;</TD></TR><TR><TD CLASS="quote">that ebp em1 looks sick im waitng for my trunklid im going wingless soon</TD></TR></TABLE>
before(allmotor and wing)
after the wing was removed...it looks alot better eh?
this was when it was onmy red hatch
Old Dec 25, 2004 | 08:25 PM
Default Re: Differences between ITR 5 lug conversion and CTR 5 lug conversion (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
And adds almost 50 lbs of unsprung weight...... </TD></TR></TABLE>
who cares when you have a fully built b16 thats turbocharged like I do I dont notice the 50lbs extra
Old Dec 25, 2004 | 08:27 PM
Aquafina's Avatar
Rear LCA's are different.
Used stock rear LCA's, stock front brake lines, and Integra rear lines on my 96 DX.
enigma94
Jan 4, 2005 06:58 AM
Uneekpinoysk8er
Nov 21, 2004 06:54 PM
midnightdarknes5
Jun 2, 2003 10:08 PM
kent
Feb 27, 2003 06:36 AM
