2 step launch control
Old Dec 4, 2008 | 04:29 PM
91lsturbocrx's Avatar
Default 2 step launch control
I'm getting an obd1 ecu for my 91 ls turbo crx. And I was wondering how exactly launch control works and if i should get it. Does the launch control come on when your completely stopped and rev it with the clutch in then does it go away when you let out the clutch?
Old Dec 4, 2008 | 04:57 PM
LA_HONDAS's Avatar
if you have hondata put a on always on and set it to disable at 1mph no higher
or you can hook it up to the e-brake or clutch with msd or hondata
i have mines on always on set to 6500 rpm's to spool the turbo after 1 mph it go's off
search launch control on youtube
Old Dec 6, 2008 | 06:12 PM
fumatch's Avatar
anti-lag, launch control
Retarding ignition
The throttle bypass/throttle solenoid system is combined with ignition retardation and slight fuel enrichment (mainly to provide cooling), typically ignition occurs at 35-45° ATDC. This late ignition causes very little expansion of the gas in the cylinder; hence the pressure and temperature will still be very high when the exhaust valve opens. At the same time, the amount of torque delivered to the crankshaft will be very small (just enough to keep the engine running). The higher exhaust pressure and temperature combined with the increased mass flow is enough to keep the turbocharger spinning at high speed thus reducing lag. When the throttle is opened up again the ignition and fuel injection goes back to normal operation. Since many engine components are exposed to very high temperatures during ALS operation and also high pressure pulses, this kind of system is very hard on the engine and turbocharger. For the latter not only the high temperatures are a problem but also the uncontrolled turbo speeds which can quickly destroy the turbocharger. http://en.wikipedia.org/wiki/Anti-lag
you should provably get your car tuned
Old Dec 7, 2008 | 06:51 PM
LA_HONDAS's Avatar
im using hondata launch control with the anti-lag cut off
hondata anti-lag suck and you dont need it and it build more boost with it off
reyesb25
Engine Management and Tuning
Jun 9, 2013 07:01 PM
vectorsolid
Jun 11, 2008 11:51 AM
CLE
Sep 11, 2006 10:06 AM
KRTRACING
May 7, 2005 12:33 PM
gsrvx
Sep 6, 2003 07:04 AM
