1st Gen B16 Head
Old Oct 10, 2001 | 10:19 AM
2.2's Avatar
2.2
Default 1st Gen B16 Head
Is there any difference between the first gen B16 head and the newer B16's we have here?
Old Oct 10, 2001 | 10:27 AM
RyanR's Avatar
Default Re: 1st Gen B16 Head (2.2)
Yeah. The cam cap rails are cast on the 1st gen head and the oil passages are a little better on the 2nd gen head. The 1st gen head also had crappy cams.
Old Oct 10, 2001 | 10:38 AM
2.2's Avatar
2.2
Default Re: 1st Gen B16 Head (97TypeR_9)
Are these differences going to be that big of a deal for like a poor mans type-r setup?
Old Oct 10, 2001 | 11:01 AM
RyanR's Avatar
If your going to be swapping out the cams then it won't really make a difference.
Old Oct 10, 2001 | 11:02 AM
EVOCELICA's Avatar
New User
No just swap out the cams, valve springs and retainers. You'll do just fine with a 1st gen.
Old Oct 10, 2001 | 11:15 AM
2.2's Avatar
2.2
Default Re: 1st Gen B16 Head (EVOCELICA)
Thanks guys, I appreciate the help. I just wish more peeps were as helpful as you guys.
Old Oct 10, 2001 | 08:45 PM
Katman's Avatar
is that avatar of yours, your real pic?
JDM bucky's rule.
[Modified by Katman, 9:46 PM 10/10/2001]
Old Oct 11, 2001 | 05:21 AM
2.2's Avatar
2.2
Default Re: 1st Gen B16 Head (Katman)
If you are asking about my avatar, then yes, it is a real pic. I got it off of http://www.uglypeople.com .
Yeah, I know the cams are poop. I am going to upgrade to ITR cams.
I found a shop near by here that will do all the machine work to the head for a B20 setup. Is 500 bucks a good deal for it? This also includes all the fittings and lines.
Old Oct 11, 2001 | 09:17 AM
stizzit's Avatar
Actually some of the 1st gen heads have less core shift - maybe it means something to you - or maybe you could care less. just my $.02
Old Oct 11, 2001 | 11:21 AM
2.2's Avatar
2.2
Default Re: 1st Gen B16 Head (stizzit)
What is core shift?
Old Oct 12, 2001 | 08:03 AM
Suprdave's Avatar
It's when the Casting (2 Molds Pressed Together with Molten Aluminum Poured in)
Shifts from it's original position, causing slight differences between each side. This can cause problem when you port the head because some surfaces might have less material than others, causing problems.
He was saying that 1st Gen Castings supposedly have less core shift, meaning they were better quality castings.
Suprdave
Old Oct 12, 2001 | 11:09 AM
2.2's Avatar
2.2
Default Re: 1st Gen B16 Head (Suprdave)
Ok, that is cool. Now I feel better about buying one of the heads.
all-mtr-teg
Jun 20, 2008 10:50 AM
DohctorVtec
12
Aug 9, 2005 08:06 PM
Suck my DX
Jul 20, 2005 05:05 PM
Suck my DX
Jun 13, 2005 09:51 AM
JDMvtecDRAGSTA
Jun 21, 2002 08:55 PM
