00 b16a2 into 98 civic dx swap problems
Old 04-18-2003, 11:45 PM
jcivic's Avatar
Default 00 b16a2 into 98 civic dx swap problems
i swap the engine in it fit fine,at first the engine would crank but would not start,then it started but idles really bad,i check everything,the spark plug wires dont have spark,but it still turns on.can somebody help!!!!!!!! i rewire a 98 ex harness to fit the si ecu.
Old 04-19-2003, 09:13 AM
Ehron's Avatar
Default Re: 00 b16a2 into 98 civic dx swap problems (jcivic)
Wires don't have spark, or the spark plugs themselves don't spark? Did you ground whatever you used to test the spark?
If it is the plugs try replacing them. Elaborate in english for more precise answers.
Old 04-19-2003, 09:27 AM
jcivic's Avatar
Default Re: 00 b16a2 into 98 civic dx swap problems (Ehron)
i did ground it ,did not get any spark from the plug wires.
Old 04-19-2003, 09:46 AM
jcivic's Avatar
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
Old 04-19-2003, 10:13 AM
lazy bum shaughn's Avatar
Maybe it's a wiring problem because I'm not sure if you can use that harness with the 99-00 ECU.
Old 04-19-2003, 10:16 AM
jcivic's Avatar
Default Re: 00 b16a2 into 98 civic dx swap problems (lazy bum shaughn)
i know but i bought the plugs that go into the ecu and rewire the harness to fit.another thing does anybody know what to do with the 2 o2 sensor,where do i put it ,and plug it up?
Race Eend
09-11-2015 02:02 PM
Rtboy10
09-22-2009 08:20 PM
kleen98accord
10-02-2007 07:17 AM
b16b18
09-06-2006 12:56 PM
Xymox007
07-30-2004 11:42 AM
Quick Reply: 00 b16a2 into 98 civic dx swap problems
