Honda S2000 Honda S2000
wheel width/offset question...
Old Jun 21, 2005 | 02:44 PM
ken-e's Avatar
Default wheel width/offset question...
wdup guys,
im new to this part of town. But i recently picked up a 00s2k
anywho, i have a set of wheels in 16x7/+43 offset all around. Obveously their meant for a fwd car, but my question is; will this offset/width be ok to run on an s2k? Can i stagger them a little by mounting wider tires in the rear?
TIA...
Old Jun 21, 2005 | 05:34 PM
Nishant's Avatar
Default Re: wheel width/offset question... (ken-e)
that offset will not work on the rear, too small. i'd find some other wheels
Old Jun 21, 2005 | 10:03 PM
ken-e's Avatar
Default Re: wheel width/offset question... (Nishant)
how so?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">that offset will not work on the rear, too small. i'd find some other wheels</TD></TR></TABLE>
Old Jun 22, 2005 | 07:43 AM
ken-e's Avatar
dont all greet me at once now, lol
Old Jun 22, 2005 | 08:56 AM
WRS2K's Avatar
Don't sell yourself short on wheels.
Wait for the right set. If you don't have the money when you find that right set, just be patient, save up some more and take care of business.
Old Jun 22, 2005 | 09:56 AM
ken-e's Avatar
Default Re: (WRS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WRS2K &raquo;</TD></TR><TR><TD CLASS="quote">Don't sell yourself short on wheels.
Wait for the right set. If you don't have the money when you find that right set, just be patient, save up some more and take care of business.</TD></TR></TABLE>i agree with your advice. The thing is, i currently have these wheels sitting in my storage. Their from an old car i had. Id hate to sell them cheap when i could possibly use them...
Old Jun 22, 2005 | 11:30 AM
WRS2K's Avatar
I know, but the fact of the matter is, you are ill served trying to "use" them on the S2000. Why would you do that to a car like the S2K?
Old Jun 22, 2005 | 05:16 PM
ken-e's Avatar
Default Re: (WRS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WRS2K &raquo;</TD></TR><TR><TD CLASS="quote">I know, but the fact of the matter is, you are ill served trying to "use" them on the S2000. Why would you do that to a car like the S2K?</TD></TR></TABLE>cause i want to know if it will be compatible; hence, this thread. Im not influenced by a simple NO. I want reasons people!
why cant i run this?
what are the down sides?
Old Jun 22, 2005 | 06:19 PM
TXS2K's Avatar
Default Re: (ken-e)
Ok, first off...what is the bolt pattern of these wheels? That has to match up. The bolt pattern for the S is 5 bolts spaced 114mm apart. The typical offsets seen on the 2000 models for a 7 inch rim is 38-40. I think a 43 might fit but it is going to set closer inside the wheel well of the car than a 40 offset. Your main problem will be the stagger. I ran a set of 7.5's all the way around on my 00 model and it didn't really effect my day to day driving, but i could not track the car that way and expect the same performance as a staggered size. I would just wait as others have stated and run a 7 inch setup up front and an 8 inch setup in the rear. That's going to give you a better performing car overall.
If you really want to know...jack the car up and remove a front and rear rim. Try putting your current rims on and see if they fit. Check for hub size, brake clearance, wheel well clearance etc. It may work, but won't be the ideal setup for the S2000. Hope that helps.
Old Jun 22, 2005 | 06:25 PM
papa5murf's Avatar
Default Re: (TXS2K)
+43 offset on a 7inch rim in the rear will fit... .. this setup will hinder handling greatly...
and the bolt patern for the S.. is 5/114.3
Old Jun 22, 2005 | 08:07 PM
ken-e's Avatar
Default Re: (TXS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TXS2K &raquo;</TD></TR><TR><TD CLASS="quote">Ok, first off...what is the bolt pattern of these wheels? That has to match up. The bolt pattern for the S is 5 bolts spaced 114mm apart. The typical offsets seen on the 2000 models for a 7 inch rim is 38-40. I think a 43 might fit but it is going to set closer inside the wheel well of the car than a 40 offset. Your main problem will be the stagger. I ran a set of 7.5's all the way around on my 00 model and it didn't really effect my day to day driving, but i could not track the car that way and expect the same performance as a staggered size. I would just wait as others have stated and run a 7 inch setup up front and an 8 inch setup in the rear. That's going to give you a better performing car overall.
they are a 5x114 bolt pattern (meant for the itr)
as far as test fitting, i did so today...they seemed to clear just fine so ive come to the conclusion that this wont be my problem.
I do agree with your performance statement, so im planning on selling these and finding a set with a rwd offset/width.
thanks for your 0.2 cents
Old Jun 22, 2005 | 08:15 PM
TallyS2K's Avatar
Default Re: (ken-e)
Good Decision
Old Jun 23, 2005 | 06:16 AM
TXS2K's Avatar
Default Re: (ken-e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken-e &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for your 0.2 cents </TD></TR></TABLE>
No prob man...always try to help out where I can.
Old Jun 23, 2005 | 08:33 AM
ken-e's Avatar
Default Re: (TXS2K)
s2k forum=
Old Jun 23, 2005 | 09:07 PM
terd ferguson's Avatar
Default Re: (ken-e)
Check my sig and buy mine.
Old Jan 23, 2006 | 03:36 PM
DEIVIONCRX's Avatar
Default Re: (terd ferguson)
Anybody know the stock sizing on the 04-05 Wheels the Split 5spoke 17" stock wheels
the fronts i would guess are 17x7 and rears are probably 17x8 but im just guessing
Old Jan 23, 2006 | 03:51 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (DEIVIONCRX)
Rears are 8.5
Old Jan 23, 2006 | 04:10 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken-e &raquo;</TD></TR><TR><TD CLASS="quote">wdup guys,
TIA...</TD></TR></TABLE>
don't run the rims...you have to stagger them
don't try to cheap out and use different width tires, or spacers or anything else you can think of...
do it right the 1st time
Old Jan 25, 2006 | 02:08 PM
DEIVIONCRX's Avatar
Default Re: (Slideways2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">Rears are 8.5</TD></TR></TABLE>
so the fronts are deffinatly 17x7?
Old Jan 25, 2006 | 05:33 PM
Second2None's Avatar
You will find out why you want to run stagger when it rains.
Old Jan 25, 2006 | 06:31 PM
madcowdk's Avatar
Default Re: (TXS2K)
Great advice!! Helpful to me as well! Thanks!!
Old Jan 27, 2006 | 10:41 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">
so the fronts are deffinatly 17x7?</TD></TR></TABLE>
Definitely.
es_squared
Oct 9, 2008 02:45 AM
RalliartRsX
Dec 12, 2005 12:34 PM
JAI-DM
May 2, 2005 04:11 PM
Curt941
Nov 22, 2004 05:25 PM
itr449
Dec 7, 2002 07:42 PM
