wheel offset question
I know I could have posted this in another section, but since it pertains to DC Integras Ill try here first. Will a 17x7.5 42mm offset fit on a lowered DC integra at all? The car is lowered about 2 1/2 inches. I know 17x7's fit fine, its just the extra .5 im concerned about. I wouldnt want to order $1400 in wheels before knowing. By the way these are the wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeaAddict »</TD></TR><TR><TD CLASS="quote">what wheels you plan on putting on it?</TD></TR></TABLE>
its right up there!...off set is fine i am not sure it will rub or not
Honestly, I would rather see a 43-45mm offest. 42mm MAY be okay, but it would be close. I am completely basing this on having 40mm offset 17x7.5 RH's, and with the car loaded with camping gear it rubbed the wheel well. If you don't load the car down, it will not be an issue for you to have 42.
