Honda S2000 Honda S2000
Rim Offset Help Please
Old Jan 10, 2010 | 05:48 PM
Tsokolate EG's Avatar
Default Rim Offset Help Please
im almost ready to buy some rims for the S and wondering if 18x8.5 all around with either an offset of +30 and +25 would fit? and my other option is 17x9 with an offset of +30
if you guys could get back to me that would be great!
Old Jan 10, 2010 | 08:31 PM
ricepicker's Avatar
Default Re: Rim Offset Help Please
None of your choices will fit properly without rolling your fenders, trimming and tucking bumper tabs, and a lot of camber. I'm running 17X8 +45 and 17X9 +45 and it is a fairly aggresive setup for the S2000 even with rolling the fenders, trimming bumper tabs and adding camber.
Old Jan 10, 2010 | 11:16 PM
anyone know what offset these wheels are?
Old Jan 11, 2010 | 03:55 AM
HondaKyle's Avatar
I hope you put some fat *** tires in the rear.
Old Jan 11, 2010 | 08:35 AM
SirStig's Avatar
Are you lowered?
Old Jan 11, 2010 | 10:30 AM
yeah im lowered on some h&r springs
Old Jan 11, 2010 | 09:46 PM
SirStig's Avatar
gotcha. +1 on most the info above then. I read a thread where someone was able to fit similar stuff a while ago just by raising the rear a bit but that was a while ago.
Old Jan 15, 2010 | 11:01 PM
vsm_EJ6's Avatar
Goodluck. You're looking at more what the guy said above.. Along with that prob a pull as well. I'd look for more s2000 friendly figments. Even the enkei rpf1 which is a very popular rim for s2ks require fender mods. The offsets on those are +48 front or +45 depending on width and +45 in the rear. If you're lowered you're lookng at a fender roll, front and rear, rear bumper tab relcation and trimming the rear bumper.
You need to research all of this..
Old Jan 16, 2010 | 04:26 PM
BlackEG6's Avatar
17x9+44 all around
Old Jan 18, 2010 | 01:09 PM
alright thanks a lot guys for the info!
Old Jan 28, 2010 | 04:36 PM
so i decided to go with 17x9 +42 rota dpt will 235 40 17 be a good size tire for this size?
Old Jan 28, 2010 | 04:53 PM
Memo6453's Avatar
What is the most aggressive setup for an s2k lowered on tein or espelirs?
For 17 " and 18" staggered... Without rolling fenders n relocating anything?
Old Jan 30, 2010 | 04:43 AM
camoy's Avatar
Here you go hope this helps, got this from another site.
Use this as a guide so you don't end up with rims that will require fender rolling or having to make severe alignment changes:
For the front:
Offsets lower than +43 are not recommended on the front because a very narrow tire would need to be used to avoid rubbing.
+43 to +47 offset: 205 tires, 6.5" - 7.5" wide wheel
+48 to +52 offset: 215 tires, 7.0" - 8.0" wide wheel
+53 to +57 offset: 225 tires, 7.0" - 8.0" wide wheel
+58 to +62 offset: 235 tires, 7.5" - 8.5" wide wheel
+63 or higher offset: 245 tires, 7.5" - 8.5" wide wheel
For the rear:
Offsets below 40 are not recommended for the rear because a tire narrower than the stock tire would need to be used to avoid rubbing.
+40 to +44 offset: 235 tires, 7.5" - 8.5" wide wheel
+45 to +49 offset: 245 tires, 7.5" - 9.0" wide wheel
+50 to +54 offset: 255 tires, 8.0" - 9.5" wide wheel
+55 to +59 offset: 265 tires, 8.5" - 9.5" wide wheel
+60 to +64 offset: 275 tires, 9.0" - 10.0" wide wheel
+65 or higher offset: 285 tires, 9.0" - 10.0" wide wheel
Old Jan 30, 2010 | 10:15 AM
95 integra's Avatar
Go with a 245 or better. I had 18X9s w/ 245s on the front of my lexus and it was a little too stretched for myself. The 18X9.5 w/ 275 in the rear was a much better fit in my opinion.
Old Jan 30, 2010 | 10:54 PM
so a 245 40 17? would that work all around?
Old Jan 31, 2010 | 05:42 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
after all this time people are still asking about offsets?
Old Feb 3, 2010 | 01:36 PM
enzozenuni's Avatar
if your going all motor like me i'd go with the same size as the AP2 rims are. I think anything bigger then that is over kill. The car was designed to be all motor so they estimated that would be best fit.
the OEM MY00-03 (AP1) wheel sizes and offsets are as follows:
Front:
16" x 6.5", +55 offset, 205 tire
Rear:
16" x 7.5", +65 offset, 225 tire
and the OEM MY04+ (AP2) wheels (including MY06) are as follows:
Front:
17" x 7.0", +55 offset, 215 tire
Rear:
17" x 8.5", +65 offset, 245 tire
Old Feb 5, 2010 | 08:16 AM
Techno Tonis's Avatar
Front:
Rear:
Front:
Rear:
What does the car being all-motor have anything to do with the offsets? lulz.
Old Feb 5, 2010 | 09:08 AM
SirStig's Avatar
i think they were talking about the tire width
Old Feb 5, 2010 | 10:46 AM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
It can be done. This is usaully a race setup and it needs quite a bit of fender rolling and pulling in the front. For a daily street car I wouldn't recomend it. If I were you I would stay staggered. 17x8/17x9 +45 all around is a common setup that only needs a slight roll in the rear. Good luck finding someone to properly roll your fenders in eastern washington lol.
Old Feb 6, 2010 | 11:23 AM
chubbylee240's Avatar
im running 18x7.5 with 235 40 18 all around. all 4 scrapes, even on the highway. i think you should run 205s or 215s. tire stretch them, should fit better then the 235s if you dont want to scrape. plus youll look like a drifter! wish i did that first
almost forgot. im lowered on skunk2 springs. fronts 2.00 drop. rears 1.4
Old Mar 20, 2013 | 08:59 PM
stag211's Avatar
Hello everyone I have a 00 ek hatch and I am looking to buy some agressive rims the rim spec I am considering is 16x8 +20 offset. Would I have a lot of camber with that set up ... Due to I am still going to use the car as a commuter I don't want to camber to much ... Please help
Old Mar 21, 2013 | 03:06 AM
dnice78's Avatar
Nice first post!
Old Mar 21, 2013 | 04:33 PM
dnice78's Avatar
check the date of op, think he cares or still has the car anymore?
Old Mar 22, 2013 | 04:09 AM
Boots's Avatar
honda-tech, where you can get advice three years later, lol
