Honda S2000 Honda S2000
Vtec on an AP1
Old May 17, 2006 | 06:36 PM
01S2KGrey's Avatar
Default Vtec on an AP1
Question for you guys and gals.
I just got my AP1 the other night, and i ran it to redline today on the way to work ( temp gauge had 3 lights). I didn't really feel the vtec kick in like I did with my civic.
So when is it suppose to change over on an AP1 (7k?) and does it hit hard? Would it throw a code if it doesn't switch over? My SOTP meter could be off seeing as how I have drive muscle for 3yrs.
Just wondering.
Thanks!
Old May 17, 2006 | 06:56 PM
Francesco's Avatar
Default Re: Vtec on an AP1 (01S2KGrey)
vtec engagement in each car varies. the ecu is very sensative to the enviorment.
some may kick in as early as 5,200rpm and others may kick in later around the 7's.
Old May 17, 2006 | 07:04 PM
- BSeRiouS -'s Avatar
Default Re: Vtec on an AP1 (FR-MOB: Francesco)
Mine kicks in 6k RPM.
I know what your talking about though. I realiized that on stock Ap1's, you can't really hear the VTEC cross over, but you can feel it pull you back though to the seat.
On my B16 power Del Sol Eg2 and my girls Si, The VTEC cross over is amazingly loud! Damn I miss that fwd
Old May 17, 2006 | 07:08 PM
jada s2k's Avatar
@ 6,000 rpm the s2 v-tech kicks in
Old May 17, 2006 | 11:53 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Vtec on an AP1 (jada s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jada s2k &raquo;</TD></TR><TR><TD CLASS="quote">@ 6,000 rpm the s2 v-tech kicks in</TD></TR></TABLE>
That must be a bad *** phone.
Old May 18, 2006 | 12:03 AM
iam7head's Avatar
Default Re: Vtec on an AP1 (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">
That must be a bad *** phone.</TD></TR></TABLE>
mine goes up to 2.8Ghz with the antenna booster
Old May 18, 2006 | 06:50 AM
LSHatch's Avatar
Default Re: Vtec on an AP1 (iam7head)
VTEC isn't some like afterburner turning on. Did you feel the car going faster? If so, then it turned on.
Old May 18, 2006 | 06:59 AM
01S2KGrey's Avatar
I just doesn't seem to hit as hard as my civic did. It may be changing over and my SOTP meter is busted because of driving the 'stang for so long.
Maybe at lunch I will go for a ride and try it again.
Would it throw a code or miss if it doesn't switch over?
Old May 18, 2006 | 07:13 AM
Shadow_S2K's Avatar
Default Re: (01S2KGrey)
If you were not engaging VTEC your car would struggle to pull to into redline.
Old May 18, 2006 | 08:05 AM
papa5murf's Avatar
an s2k is a very differnt car then a civic... just becuase you did this or that or felt this and that with a civic doesn't mean you'll get the same in the S....
papa5murf's Avatar
i used to have a v-tech cordless phone in my house.... LOL...
Old May 18, 2006 | 08:10 AM
LSHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01S2KGrey &raquo;</TD></TR><TR><TD CLASS="quote">I just doesn't seem to hit as hard as my civic did. It may be changing over and my SOTP meter is busted because of driving the 'stang for so long.
?</TD></TR></TABLE>
It may not hit as hard as your Civic did. The S will get louder at VTEC, but not some insane amount.
Like someone posted, the S will struggle to get to 9k without VTEC engaging.
Old May 18, 2006 | 08:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">
i used to have a v-tech cordless phone in my house.... LOL...</TD></TR></TABLE>
you must be a fool if you don't have a v-tech phone.
haha.
hahahahah
Old May 18, 2006 | 08:38 AM
TomTomTuning's Avatar
Default Re: Vtec on an AP1 (OBSeRiouso)
Vtec Engages smoothly on the S2K not like some of the other B/H series engines
The A/F is a big reason, When tuning a Map you can make Vtec engage harder by what the A/F is at that moment
Old May 18, 2006 | 09:09 AM
01S2KGrey's Avatar
Sounds good. It certainly doesn't struggle to get to 9k.
Thanks for the replies.
Old May 18, 2006 | 09:20 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouso &raquo;</TD></TR><TR><TD CLASS="quote">
vtech cordless
Old May 18, 2006 | 11:01 AM
evil vapor's Avatar
Default Re: Vtec on an AP1 (Yoshi ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yoshi ek &raquo;</TD></TR><TR><TD CLASS="quote">Vtec Engages smoothly on the S2K not like some of the other B/H series engines
It has nothing to do with the air fuel ratio. The cam profiles on the primary and vtec lobes determine vtec transition.
Old May 18, 2006 | 03:11 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Vtec on an AP1 (evil vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">
It has nothing to do with the air fuel ratio. The cam profiles on the primary and vtec lobes determine vtec transition.</TD></TR></TABLE>
yes sir that is soooooo true.....
if u want it to "kick in" take off the top cover to your air box.. then run it you'll hear it for sure!
Old May 18, 2006 | 03:17 PM
LSHatch's Avatar
Default Re: Vtec on an AP1 (FR-MOB: SnoFlake)
I just drove a stock S2k today for the first time in a while. Yeah, there is no audible VTEC crossover.
Old May 18, 2006 | 06:18 PM
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01S2KGrey &raquo;</TD></TR><TR><TD CLASS="quote">Question for you guys and gals.
Just wondering.
Thanks!</TD></TR></TABLE>
Vtec kicks in at 6K on the AP1. If your running the stock air box then you won't really hear, or even feel it that much. Throw an aftermarket intake on her and you'll definately know when your in vtec
Old May 18, 2006 | 06:42 PM
01S2KGrey's Avatar
I tried it again and I notice it kicked in about 6k. Just wasn't as aggressive as my civic (atleast it seems so) but then again my civic had quite of bit of work done to it and this car is stock
Thanks again for the help.
Old May 18, 2006 | 07:17 PM
ROCAFELLA2049's Avatar
I know I'm stealin this from somebody but it's too good not to use with that Post.
Old May 18, 2006 | 07:26 PM
Moemers's Avatar
Default Re: (ROCAFELLA2049)
VTEC should kick in at 6200 rpms. don't really think climate has much to do with it...
my VTAK blows off...whatchu know about dat?
Old May 18, 2006 | 07:30 PM
maniach4x's Avatar
I just wanted to put my two cent in, On stock honda you should not feel Vtec "kick" in it should be nice change over if the car is tuned right, the S2000 is one of Honda Top tuned cars and your not going to feel it kick in Hard. Unless you start mods but even then you want it to be a nice change over with good tuning.
Old May 19, 2006 | 12:11 AM
* B A N N E D *
Default Re: (maniach4x)
She doesn't kick, be she sure does jump.
