Honda S2000 Honda S2000
Using a different ecu
Old Apr 10, 2008 | 12:33 PM
wrayzor's Avatar
Default Using a different ecu
Background is my buddy bought an s2000 with a blown motor (1 and 2 cyl's fried) and he bought a longblock and along with it an ecu from another car. The s2k that he bought had a vortech on it and he is trying to basically get everything back to stock to just drive it and my question is what does he need to do to be able to use this ecu from a different car in his if anything. His car is an '04 and the ecu is an '05. If you need anymore details id be glad to give them.
Thanks
Old Apr 10, 2008 | 01:14 PM
joey1320's Avatar
Default Re: Using a different ecu (wrayzor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrayzor &raquo;</TD></TR><TR><TD CLASS="quote">Background is my buddy bought an s2000 with a blown motor (1 and 2 cyl's fried) and he bought a longblock and along with it an ecu from another car. The s2k that he bought had a vortech on it and he is trying to basically get everything back to stock to just drive it and my question is what does he need to do to be able to use this ecu from a different car in his if anything. His car is an '04 and the ecu is an '05. If you need anymore details id be glad to give them.
Thanks </TD></TR></TABLE>
as long as the ecu is stock is just plug and play
Old Apr 10, 2008 | 02:15 PM
ricepicker's Avatar
Default Re: Using a different ecu (joey1320)
I haven't had any experience with switching ECU's. But I've heard that you need to have the keys reprogrammed because of the immobilizer.
But then again, if you are just replacing the motor, you should still be able to use the factory 04 ECU on the 05 motor.
Old Apr 11, 2008 | 03:56 AM
JDM knowledge's Avatar
Default Re: Using a different ecu (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">I haven't had any experience with switching ECU's. But I've heard that you need to have the keys reprogrammed because of the immobilizer.
But then again, if you are just replacing the motor, you should still be able to use the factory 04 ECU on the 05 motor.</TD></TR></TABLE> needs to go to honda to have the key synced with your solenoid and ECU. There is a brake code for our cars with a series of brake pedal presses and you can start it. But if its a difference ECU from the car i dont think it will work.
ribal_gh
Honda S2000
Sep 18, 2013 01:47 AM
alexs2k
Honda S2000
44
Mar 12, 2008 07:43 AM
B Dawg
Dec 23, 2007 11:49 AM
Cornering Artist
Honda S2000
Mar 2, 2007 06:03 PM
faygay79
Honda S2000
Nov 29, 2006 10:14 PM
