Honda S2000 Honda S2000
s2000 ecu question?
Old Nov 24, 2006 | 06:31 PM
faygay79's Avatar
Default s2000 ecu question?
Ok a little while back my s2000 was broken into and my ecu was stolen
Ive been running what i believe is a JDU ecu a friend of a friend had laying around
Works fine but it throws a check engine light
So I ordered one from honda becuase the check engine frankly freaks me out a little even though the cars seems perfect
Well installed the Ecu and it doesn't seem to work! Immobilizer is flashing and it just doesn't start?
Is this the wrong ecu?
Any feedback would be greatly appreciated
Thanks guys!
This is a 04 s2 btw
Old Nov 24, 2006 | 06:57 PM
S2KDriver03's Avatar
Default Re: s2000 ecu question? (faygay79)
Personally it sounds like eather the ecu you recieved was damaged or the wrong one, I would call a local honda dealer so you can double check the part numbers.
Nate
Old Nov 25, 2006 | 12:55 AM
iam7head's Avatar
Default Re: s2000 ecu question? (S2knate8811)
don't you have to program you key to work with the immobilzer/ecm?
Old Nov 25, 2006 | 10:35 AM
Mr. Projekt's Avatar
* B A N N E D *
Using a brand new ECU requires reprogramming of the 04+ blade keys. $75 IIRC.
Old Nov 25, 2006 | 12:13 PM
Default Re: s2000 ecu question? (FR-MOB: Projekt)
Looks like you gotta get it reprogrammed....
Old Nov 25, 2006 | 05:38 PM
ladius's Avatar
yes, as others already said, you have to the ecu programmed with the vin and paired to the immobilizer chip in the key. only honda can do it with a special programming tool. I had this done as well and I called around to other mechanic shops to see if they could reprogram for cheaper but they all said they don't have that tool.
Old Nov 25, 2006 | 06:33 PM
faygay79's Avatar
yeah thanks for the info guys....
good chance to get a back up key made since i bought the car with only one key
thanks fellas!
Old Nov 29, 2006 | 10:14 PM
b.somethin's Avatar
this thread is faygay... sike nah make a key
mita
Aug 28, 2014 11:46 PM
ribal_gh
Honda S2000
Sep 18, 2013 01:47 AM
B Dawg
Dec 23, 2007 11:49 AM
