Honda S2000 Honda S2000
torque wrench ques.
Old Apr 2, 2006 | 03:54 PM
mellowhead's Avatar
Default torque wrench ques.
I need to get a torque wrench and I'm not sure which one to get. I just need it for the S. things like oil bolt, diff, tranny bolt, lug nuts, brakes. What can I grab at the local Advanced or pep boys, autozone?
Old Apr 2, 2006 | 07:44 PM
hatch4raceb16's Avatar
Default Re: torque wrench ques. (mellowhead)
You can actually rent them from autozone, etc. I would not suggest buying one from there however, they are free to rent, just leave a security deposit.
If you want to buy one, go with atleast Craftsman or higher.
Old Apr 2, 2006 | 10:50 PM
iam7head's Avatar
Default Re: torque wrench ques. (hatch4raceb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch4raceb16 &raquo;</TD></TR><TR><TD CLASS="quote">You can actually rent them from autozone, etc. I would not suggest buying one from there however, they are free to rent, just leave a security deposit.
If you want to buy one, go with atleast Craftsman or higher.</TD></TR></TABLE>
rental torque wrench? no thank you, it must been dropped and used as breaker bar by ricer and a like.
100-150 will get you some nice one, snap-on or craftsman are great.
Old Apr 2, 2006 | 11:45 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mellowhead &raquo;</TD></TR><TR><TD CLASS="quote">I need to get a torque wrench and I'm not sure which one to get. I just need it for the S. things like oil bolt, diff, tranny bolt, lug nuts, brakes. What can I grab at the local Advanced or pep boys, autozone? </TD></TR></TABLE>
You shouldn't need a torque wrench for the oil/diff/tranny bolts or brake bolts. Use common sense and don't over-tighten, keeping in mind the size of the bolt and the aluminum it's being threaded into is soft.
I use a torque wrench on lug nuts just for peace of mind. Unless you're putting an engine together, don't worry about using a snap on or craftsman torque wrench. Get some anti-seize, preferably the copper stuff, and use that on your lug nuts.
Old Apr 3, 2006 | 06:35 AM
mellowhead's Avatar
Default Re: torque wrench ques. (vapor)
Thanks Guys. Great Info.
Old Apr 3, 2006 | 08:24 AM
vtec.dc2's Avatar
torque wrench are always good to have, i have 2.. one for lug nuts, and more expensive one when i service the car. spark plugs, oil drain plug, valve adjustment.. i torque everything to whatever manual says.
Old Apr 3, 2006 | 10:51 AM
mellowhead's Avatar
Default Re: torque wrench ques. (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
torque wrench are always good to have, i have 2.. one for lug nuts, and more expensive one when i service the car. spark plugs, oil drain plug, valve adjustment.. i torque everything to whatever manual says.</TD></TR></TABLE>
Which brand?
Old Apr 3, 2006 | 11:06 AM
cmdr430's Avatar
Craftsman work just fine.....
Old Apr 3, 2006 | 11:07 AM
WowOzYouRock's Avatar
i never use torque wrench unless im working on the engine ... i have a snap on one and i dont even use it on the lug nuts etc. ... my right arm is calibrated to each bolts factory specs
Old Apr 3, 2006 | 05:53 PM
Rtzx9r's Avatar
GDD 1%
Default Re: torque wrench ques. (Honda-Tech-Jerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech-Jerk &raquo;</TD></TR><TR><TD CLASS="quote"> my right arm is calibrated to each bolts factory specs </TD></TR></TABLE>
Is it calibrated in Ncm or Ft-Lb?
I have a craftsman digitork 1/2 for lug nuts and a 3/8 for engine bolts and lower torque applications. I have had them for many years (5+) and they hold up well. Do not buy a cheap one or rent one. One mistake will cost you much more than buying a decent one.
Old Apr 3, 2006 | 08:13 PM
Default Re: torque wrench ques. (Rtzx9r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtzx9r &raquo;</TD></TR><TR><TD CLASS="quote">
I have a craftsman digitork 1/2 for lug nuts and a 3/8 for engine bolts and lower torque applications. I have had them for many years (5+) and they hold up well. Do not buy a cheap one or rent one. One mistake will cost you much more than buying a decent one.</TD></TR></TABLE>
Renting one is just fine for something like lug nuts or engine oil drain bolts. I agree though, for anything internally related, I would just buy one. I was just saying that he could rent one if he needed.
Craftsman digitork rock
Old Apr 3, 2006 | 08:25 PM
Mr. Projekt's Avatar
* B A N N E D *
Get an electronic one.
I use a Snap-On digital and an older Craftsman clicker.
Old Apr 4, 2006 | 03:37 PM
granracing's Avatar
For the stuff your looking at using it for, but a cheapie one. Rent one? If you ever decide to do engine work, then you need a much higher quality unit. I bought mine at one of those dollar stores for under $10 (the clicker type). Before my friend did some testing with the one he bought at the same store with their shop's very expensive ones, I would have thought he was crazy. After seeing him use it on his car while he has access to the other ones, I became convinced.
(No matter which torque wrench you choose to buy, only use it to tighten not loosen stuff.) I've had mine for over three years now and still am very happy with my $10 torque wrench.
Old Apr 4, 2006 | 05:53 PM
* B A N N E D *
Default Re: (granracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granracing &raquo;</TD></TR><TR><TD CLASS="quote">
No matter which torque wrench you choose to buy, only use it to tighten not loosen stuff.) </TD></TR></TABLE>
Old Apr 5, 2006 | 03:31 PM
vtec.dc2's Avatar
Which brand?</TD></TR></TABLE>
for the wheels, i got 1/2" $20-30 from local auto store, my better wrench is 3/8" crafstman, cost 100 dollars and easy to use, has a display for torque settings
Old Apr 6, 2006 | 06:07 PM
FULL-REV's Avatar
Get the snap on one with the adjustable **** which clicks when you reach the specified torque level.
Old Apr 7, 2006 | 11:18 AM
mellowhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech-Jerk &raquo;</TD></TR><TR><TD CLASS="quote">i never use torque wrench unless im working on the engine ... i have a snap on one and i dont even use it on the lug nuts etc. ... my right arm is calibrated to each bolts factory specs </TD></TR></TABLE>
so what does the left one do?
Old Apr 7, 2006 | 02:33 PM
* B A N N E D *
You don't wanna know buddy.
TypeRuz
Aug 25, 2013 01:41 PM
ninjaturtleEG
Nov 23, 2011 03:18 PM
tonezilla
Feb 27, 2005 08:08 AM
mnbv
Aug 16, 2004 10:05 AM
david90
Aug 6, 2003 03:42 AM
