Honda S2000 Honda S2000
TestPipe Question
Old Dec 4, 2006 | 07:08 PM
chinkieboy's Avatar
Default TestPipe Question
Looking for opinion on aftermarket testpipe in a stock car, what brand is good, pros and cons on them. is this worth it? stock exhasut with aftermarket test pipe, anybody have this on their car?
Old Dec 4, 2006 | 07:32 PM
- BSeRiouS -'s Avatar
Default Re: TestPipe Question (*****ieboy)
Pro: Free's up nice hidden horse power, more free flowing.
Cons: It smell that it emits is intoxicating, illegal.
Just about any other test pipe out there is the same. The only thing you'll be paying for is name.
you have your "cheaper" ones such as Invida, Megan, helix, etc.
and you have your "better than normal" ones such as T1R, Berk, etc.
and then you have your "better than better" ones such as J's, Amuse, etc.
Old Dec 4, 2006 | 08:04 PM
chinkieboy's Avatar
so u think its worth it with stock exchust and header?
Old Dec 4, 2006 | 08:31 PM
LAS2K's Avatar
Default Re: (*****ieboy)
no...header, stock cat, and diff exhaust.
Old Dec 4, 2006 | 08:39 PM
chinkieboy's Avatar
so its not worth it just to change the test pipe?
Old Dec 4, 2006 | 08:45 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy &raquo;</TD></TR><TR><TD CLASS="quote">so u think its worth it with stock exchust and header?</TD></TR></TABLE>
Aftermarket header and test pipe with a stock exhaust did wonders for me.
Old Dec 5, 2006 | 08:57 AM
TomTomTuning's Avatar
Default Re: (Francesco)
I work a "Becks" test pipe with fujitsubo exhaust.
the smell at first gets your worried, but its common for S2ks with test pipes.
as far as HP gain, i dont think its much.
Next on my list, Header + Intake system
Old Dec 5, 2006 | 09:41 AM
chinkieboy's Avatar
but if i don't change header or exhaust, is it a good idea just to change the testpipe??
Old Dec 5, 2006 | 09:54 AM
iam7head's Avatar
it doesn't really matter because neither way you end up with just a tad more hp and that's it.
as far as test pipe goes, most of the is 90% the same, so get teh cheapest one
Old Dec 5, 2006 | 10:23 AM
Francesco's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
as far as test pipe goes, most of the is 90% the same, so get teh cheapest one</TD></TR></TABLE>
Cheap isnt always the way to go.
Im not saying buy the 400$ amuse test pipe, but theirs a big difference between the Berk Technologies test pipe and a 50$ ebay test pipe. Just buy what works and what people are using with no problems and like.
Old Dec 5, 2006 | 10:40 AM
chinkieboy's Avatar
so looks like j's or T1R are the most popular one
Old Dec 5, 2006 | 10:42 AM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy &raquo;</TD></TR><TR><TD CLASS="quote">so looks like j's or T1R are the most popular one</TD></TR></TABLE>
I have the j's, I like it. It wasn't too expensive and does the job. All I had to do was make a mechanical o2 simulator so I didn't throw a CEL. Two years with it and still no CEL, no bad smell, no noises and it sounds and performs great.
Old Dec 5, 2006 | 11:03 AM
Curiouz_G's Avatar
no smells? maybe you just got use to it
Old Dec 5, 2006 | 11:06 AM
Default Re: (Curiouz_G)
yea i was thinking the same..
I seriously think my car burns more oil then what it should be.
like i understand the S2000's are known fow burning a little oil here and there.
but my car has 36K and when i really get on it (from the hole) i can see a little smoke. now its not ALOT...
i seriously need to look into that a little more
Old Dec 5, 2006 | 12:28 PM
chinkieboy's Avatar
anyone experienced T1R? easy install? and problems with it?
Old Dec 5, 2006 | 01:25 PM
EG-B18CR's Avatar
megan racing
its cheap, and fits nicely
check the s2ki.com for sale section, i usually see used test pipes there.
Old Dec 5, 2006 | 05:39 PM
dc5 jared's Avatar
Default Re: (EG-B18CR)
just got mine...have yet to install it. its a berk's test pipe with flanges custom welded on to it, to connect the stock cat heat shields.
should flow good with my soon-to-buy j's 60rs exhuast.
Old Dec 5, 2006 | 10:13 PM
I have the T1R 70 Version 2 test pipe that slips right into the exhaust w/ no flanges. (well actually one flange that connects to the header)
the traditional test pipes are cake when installing. Just drop the cat, use the existing flanges, take the test pipe, and bolt it up. Done.
Old Dec 6, 2006 | 06:11 AM
Nuts's Avatar
Default Re: (OBSeRiouSo)
Does test pipe give you guys CEL?
Old Dec 6, 2006 | 07:31 AM
chinkieboy's Avatar
yes thats the other thing im worry about, CEL.
Old Dec 6, 2006 | 10:38 AM
Default Re: (Nuts)
Yes the test pipe will throw a cell on your car.
The only way to work around this is quite easy. Go to your local automotive parts store such as Napa/Kragen/Pep Boys etc.
and pick up some Anti-Spark foulers. They usually run like 6 bux and some change. (you will get a pair)
Steps:
1) Remove 02 sensor if you haven't already done so
2) take one anti-fouler and screw it in the 02 bung
3) locate a power drill
4) Find a 1/2 Drill bit
5) take the other anti-fouler and drill the 1/2 bit straight through the existing hole
6) Screw on the "modded" anti-fouler to your other anti fouler
7) Connect 02 Sensor to the "modded" anti-fouler and voila. No Cell.
Reason to drill the anti fouler a 1/2 inch is beacuse the 02 sensor's tip will not fit into it.
Have a good day.
Old Dec 6, 2006 | 10:52 AM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo &raquo;</TD></TR><TR><TD CLASS="quote">Yes the test pipe will throw a cell on your car.
Steps:
Have a good day.
works wonders. ive had this for over 2 years now, no CEL
Old Dec 6, 2006 | 03:53 PM
batguano's Avatar
My Invidia Test pipe came with the O2 simulator. No CEL.
Old Dec 7, 2006 | 12:05 PM
EG-B18CR's Avatar
i also use that bung, I've gone through two oil changes cel free.
Old Dec 7, 2006 | 12:14 PM
fred92htch's Avatar
Default Re: (TomTomTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TomTomTuning &raquo;</TD></TR><TR><TD CLASS="quote">yea i was thinking the same..
but my car has 36K and when i really get on it (from the hole) i can see a little smoke. now its not ALOT...</TD></TR></TABLE>
I have the Berks testpipe and noticed the same thing a while back. Not a lot, but just a very small puff on take-off. I have 52k miles.
