Honda S2000 Honda S2000
test pipe vibration
Old Oct 4, 2007 | 02:39 PM
megalomaniac001's Avatar
Default test pipe vibration
I just put my Berk test pipe on and when i tighteded the spring bolts on the header side i ran it all the way to the end of the threads and it didnt make it very tight so it's rattling when i idle down. anyone else run into this problem and how did you fix it. im thinking about just getting some washers and spacing the bolts out so the springs will hold everything better.
Old Oct 4, 2007 | 03:56 PM
LumpyTheGrumpyCamshaft's Avatar
Default Re: test pipe vibration (megalomaniac001)
did you use lock tight ?
did you use washers just below the bolt head ?
Old Oct 4, 2007 | 04:41 PM
papa5murf's Avatar
Re-tighten. You shouldn't need locktite.
Old Oct 4, 2007 | 04:51 PM
the soL that could's Avatar
before you go out purchasing stuff...
I have an 07 and i purchased the Berks TP also. It did not fit correctly and i had to cut/weld/reflange it. Also you might need to do that spark plug fouler mod. because a CEL will trigger. even though they claim the built in 1 will work.
Old Oct 4, 2007 | 06:56 PM
Default Re: test pipe vibration (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Re-tighten. You shouldn't need locktite. </TD></TR></TABLE>
ill try it...got to let it cool off now...just got through with some spirited driving the only thing about just re-tightening is that the bolts with the springs on it were down to the end of the thread...in other words it wouldnt go any tighter
Old Oct 4, 2007 | 09:59 PM
b20integrapower's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megalomaniac001 &raquo;</TD></TR><TR><TD CLASS="quote">
ill try it...got to let it cool off now...just got through with some spirited driving the only thing about just re-tightening is that the bolts with the springs on it were down to the end of the thread...in other words it wouldnt go any tighter </TD></TR></TABLE>
you put the springs on the wrong side i bet.
Old Oct 5, 2007 | 04:08 AM
papa5murf's Avatar
Default Re: test pipe vibration (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">
you put the springs on the wrong side i bet.</TD></TR></TABLE>
I agree.
Old Oct 5, 2007 | 04:36 AM
i made sure i put them on the same way i took them off
Old Oct 5, 2007 | 05:24 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megalomaniac001 &raquo;</TD></TR><TR><TD CLASS="quote">i made sure i put them on the same way i took them off</TD></TR></TABLE>
Maybe you need some new bolts/nuts/springs.
Old Oct 6, 2007 | 06:23 PM
I FIXEDED IT!!! o2 sensor was rattling loose. some lock tight and a breaking bar got it to stop.
Old Oct 7, 2007 | 07:55 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megalomaniac001 &raquo;</TD></TR><TR><TD CLASS="quote">I FIXEDED IT!!! o2 sensor was rattling loose. some lock tight and a breaking bar got it to stop. </TD></TR></TABLE>
Oh man, completely forgot about telling you about that. hahaha. Same thing happened to me when I installed it back in the days. haha
MADBADGER
Honda S2000
25
Nov 29, 2007 04:56 AM
93civichatchinky
Sep 15, 2007 04:25 PM
tusnamiep3
Aug 23, 2007 08:04 PM
ITB
Nov 20, 2005 07:22 PM
zer0zer0 TypeR
Jul 30, 2002 06:33 PM
