Honda S2000 Honda S2000
test pipe ?
Old Feb 12, 2004 | 08:58 PM
jaycuzz1's Avatar
Default test pipe ?
has anyone put a test pipe on yet ? does it throw a check engine light ? and how much louder does it get ? did it increase hp ?
thanks
Old Feb 13, 2004 | 01:12 AM
evil vapor's Avatar
Default Re: test pipe ? (jaycuzz1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaycuzz1 &raquo;</TD></TR><TR><TD CLASS="quote">has anyone put a test pipe on yet ? does it throw a check engine light ? and how much louder does it get ? did it increase hp ?
thanks</TD></TR></TABLE>
yes, you'll get a MIL and no, the code it throws will not alter performance. If you don't have a means of altering the fuel or ignition, it's not worth the hassle if you get caught in Cali with one or the stinky smells associated with one. One more thing...car will be a lot louder/raspy.
Old Feb 16, 2004 | 07:51 PM
Razor's Avatar
Default Re: test pipe ? (vapor)
what fuse can you pull to get rid of the light? isn't it the ecm reset fuse?'
Old Feb 16, 2004 | 08:37 PM
Voodoo_s2k's Avatar
Default Re: test pipe ? (Razor)
You can reset the ecu, but it will keep on coming back unless you run a simulator.
Old Feb 16, 2004 | 09:06 PM
M.J.M.'s Avatar
Default Re: test pipe ? (Voodoo_s2k)
Not worth it, IMO.
Old Feb 16, 2004 | 09:45 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">what fuse can you pull to get rid of the light? isn't it the ecm reset fuse?'</TD></TR></TABLE>
it should be the radio back up fuse, but that will kill the beeping sound when your doors are open, reset your ecu everytime you start your car and may give you a slightly different idle and your AC will continue to turn on in the defroster mode if you changed it so it doesn't turn off. You can live with the MIL on, it's no big deal.
Old Feb 16, 2004 | 09:46 PM
evil vapor's Avatar
Default Re: test pipe ? (M.J.M.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.J.M. &raquo;</TD></TR><TR><TD CLASS="quote">Not worth it, IMO. </TD></TR></TABLE> not worth killing the whales and trees and environment?
Old Feb 17, 2004 | 06:52 AM
DongTran's Avatar
If it can be had cheap, why not?
r1ch1e
Apr 4, 2006 10:27 AM
mfzbike
Feb 10, 2006 02:06 PM
JDMsocalcivic
22
Feb 4, 2006 07:54 AM
B18_Turbo
Honda S2000
Jul 11, 2005 12:44 PM
SuicideSlide
10
Sep 23, 2004 05:58 AM
