Honda S2000 Honda S2000
tein flex or ground control/konis
Old Jul 31, 2005 | 08:26 PM
ekallstar21's Avatar
Default tein flex or ground control/konis
hey guys, ive been searchin all over the s2ki forums(been actin up lately) and honda-tech and i just wanted to get the opinions of those who own both these set ups.... which one would you prefer and why? are the teins worth it or should i just go with a custom rate ground control coilover set and some konis?thanks in advance for your guys help
Old Jul 31, 2005 | 08:51 PM
MaxGeek's Avatar
I don't own either of these but from what I've read the Teins are more for the street then the track as they are really soft. The koni's and GC coilovers have more potential for track/autocross use.
So it depends what you are going for.
Old Jul 31, 2005 | 08:55 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: tein flex or ground control/konis (ekallstar21)
The Koni/GC combo is a better product and you have a better range of tuning w/ custom valving as an option and a ton of different spring rates available.
Old Aug 1, 2005 | 09:05 PM
Will_ChinLee's Avatar
if your intrested in track i'd go neither.. look into some higher end stuff. Tein RAs is what i'm planning on running, since i can't afford the RSs. Flex is a dual tube damper which = durability not performance.
If for streets... i won't matter what you get... you won't be able to push your car that far... well you probably could but that would be dangerous...
Old Aug 2, 2005 | 12:46 AM
Default Re: (Will_ChinLee)
what kinda suspension are you ridin on?
Old Aug 2, 2005 | 03:28 AM
i tracked stock.. which was very good. and since i do plan on tracking my car i decided to get the RAs. since we have such a good stock suspension, most aftermarket stuff is a downgrade. only the higher coilovers will truely be an upgrade in handling. i'm picking up my Tein RAs this weekend. i'll let you know how they work out.
Old Aug 2, 2005 | 02:12 PM
alright, that sounds like a plan... thanks bro, ill be waitin on your review of em
Old Aug 2, 2005 | 03:19 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: (ekallstar21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">The Koni/GC combo is a better product and you have a better range of tuning w/ custom valving as an option and a ton of different spring rates available.</TD></TR></TABLE>
Nice plug since the GC include eibach springs
From personal experience, GC or any coilover(not full damper assembly) will have a terrible ride quality and worse performance. I've done research on this topic as well, and I would go with an aggressive spring on the Koni's. Or if money isn't an issue, buy the entire coilover set up. Here are some opinions on full coilovers...
https://honda-tech.com/zerothread?id=1319242
Old Aug 2, 2005 | 03:24 PM
WowOzYouRock's Avatar
Default Re: tein flex or ground control/konis (vtecvoodoo)
not to mention hes a lil bit bias
Old Aug 2, 2005 | 04:51 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: (NAallTheWAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY &raquo;</TD></TR><TR><TD CLASS="quote">
From personal experience, GC or any coilover(not full damper assembly) will have a terrible ride quality and worse performance. </TD></TR></TABLE>
I guess most of the guys who run ECHC and WCHC are wrong. And my s2k and racecar must be horrible.
And what is "an aggressive spring on the Koni"?
Old Aug 2, 2005 | 05:55 PM
humanshield's Avatar
Default Re: (vtecvoodoo)
the stock suspension is VERY trackable. i feel you run the risk of ruining a very great suspension, unless you really spend some money. i know several of my friends did trial runs to test some suspensions, and the stock setup ran quicker in almost every run. many will disagree with me, but that's my two cents.
Old Aug 2, 2005 | 06:46 PM
EFSS153
I said from my experience with a GC coilover I wasn't happy with the results. I've owned two cars with an aftermarket strut/GC coilover combo. In both instances, I had better results with a simple spring.
Old Aug 2, 2005 | 06:52 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Did you corner weigh the vehicle?
Old Aug 2, 2005 | 06:56 PM
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">Did you corner weigh the vehicle?</TD></TR></TABLE>
On my CRX, yes.
Old Aug 3, 2005 | 05:25 AM
B--RYAN's Avatar
tein arent bad
Old Aug 3, 2005 | 10:33 AM
Francesco's Avatar
Default Re: (B--RYAN)
im selling my Tein flex with EDFC...had them for less than a year, under 8k miles on them...No problems, im just up grading to the Zeals
Old Aug 3, 2005 | 11:23 AM
bridow's Avatar
Default Re:
flexes arent bad. they are pretty good for autox even though some people say they arent. my friend won solo2 nationals on flexes. so they cant be all that bad
i wouldnt get the RAs...a LOT of guys on the s2k board are selling them because they are unbareable on the street. just my two cents. im planning on upgrading to the tein CSs mainly because i live downtown and want a smoother ride. if anyone wants teins, just drop me a line. i have a pretty good hook up on them. i can get the flexes for the s2k for 1200 + shipping.
CastCust
Jan 25, 2008 07:53 AM
jdm_r1
Suspension & Brakes
Apr 10, 2007 01:44 PM
lxaccord51oxl
Nov 25, 2006 11:35 AM
Understeer
Jan 22, 2003 02:24 PM
EBPSI
Sep 22, 2002 12:34 AM
Top
Follow Us
