Honda S2000 Honda S2000
Stock Rod power capabilities
Old Nov 9, 2004 | 04:07 PM
ArinX's Avatar
Default Stock Rod power capabilities
I dont know how you would figure this out, but what are the stock rods on the f20c capable of holding?
Thanks in advance
Old Nov 11, 2004 | 02:55 PM
greenmonster's Avatar
Default Re: Stock Rod power capabilities (ArinX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX &raquo;</TD></TR><TR><TD CLASS="quote">I dont know how you would figure this out, but what are the stock rods on the f20c capable of holding?
Thanks in advance</TD></TR></TABLE>
that's a many fold question.
it can mean 20lbs of boost in a few minutes
10lbs daily possible with injectors and EMS
Old Nov 11, 2004 | 08:35 PM
Mr. Projekt's Avatar
* B A N N E D *
they hold the pistons. BAHAHAHA
break down your f20 and bang on your rods with a sledge, then post your results.
Old Nov 12, 2004 | 07:34 AM
ArinX's Avatar
Default Re: Stock Rod power capabilities (WannaBeDrifter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WannaBeDrifter &raquo;</TD></TR><TR><TD CLASS="quote">they hold the pistons. BAHAHAHA
break down your f20 and bang on your rods with a sledge, then post your results.</TD></TR></TABLE>
WOW you really helped! Dude you should be a mod!
i guess i meant hp figures
Modified by ArinX at 1:15 PM 11/12/2004
Old Nov 12, 2004 | 11:33 AM
fknfast's Avatar
350-400hp
Old Nov 12, 2004 | 01:38 PM
Jeremyinlinepro's Avatar
We are making 450whp@18psi on pump gas with our project car. We have put over 6000 miles on it at that level and we purposely abuse it to try to find the limitations. It is a stock motor with our 3mm headgasket. We strongly feel that they will support at least 550whp if not more.
Old Nov 12, 2004 | 10:22 PM
ArinX's Avatar
Default Re: Stock Rod power capabilities (Jeremyinlinepro)
thanks for reply!
question about the 3mm headgasket... does the timing chain tensionor have enough adjustment to makeup for the increased distance between the head and the block
Old Nov 13, 2004 | 02:22 PM
HamiltonRex's Avatar
Someone should do an altimate rod test!
Take stock/aftermarket rods.
Put them in one of thouse hydraulic machines that they use to crush blocks of cement to see how strong they are.
Set it in that machine, see how much weight they can hold before they bend!
-Eric
Old Nov 14, 2004 | 12:27 AM
Pacman
Guest
Posts: n/a
Someone is buying a S2K
Old Nov 14, 2004 | 01:41 AM
ArinX's Avatar
Default Re: Stock Rod power capabilities (Pacman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pacman &raquo;</TD></TR><TR><TD CLASS="quote">Someone is buying a S2K </TD></TR></TABLE>
Hopefully!
Old Nov 15, 2004 | 01:21 PM
We modify the gears to compensate for the headgasket
Old Nov 15, 2004 | 01:35 PM
BOOSTEDS2K's Avatar
I have the inline pro kit and at 18 psi and race gas I made over 500 hp but the thing with inline pro is they use an afc..... thats just a time bomb waiting to blow.... I have the set up that Jeremyinlinepro is talking about but with a few diff things for and my car runs fine and shows no sign of anything rong.... I talked to the owner of inline pro and he said they think it will hold up to 600 hp....
Old Nov 16, 2004 | 08:08 AM
ArinX's Avatar
thanks for the replys/info guys
Old Nov 18, 2004 | 08:25 AM
marques4130's Avatar
sorry off topic, has anyone had any experience with how much power the stock drivetrain can hold?
b20_driven
Aug 6, 2008 05:20 PM
turbo boost
Oct 16, 2006 01:04 PM
Mangudai
Apr 5, 2006 11:07 PM
thehatchninja
Aug 29, 2005 10:44 AM
dabig1
Sep 30, 2004 01:05 PM
