Honda S2000 Honda S2000
Spinning stud need help!
Old Aug 4, 2006 | 05:00 PM
dc2woohoo's Avatar
Default Spinning stud need help!
Anybody have any ideas how to get a lugnut off if the stud is spinning with it? My brakes are grinding pretty bad and I can't get my wheel off. Thanks in advance.
Old Aug 4, 2006 | 05:06 PM
Miracle's Avatar
Default Re: Spinning stud need help! (dc2woohoo)
Im assuming youll have to cut it off.
The splines that hold the stud still in the hub are stripped, but how in the hell did that happen?
Old Aug 4, 2006 | 05:13 PM
dc2woohoo's Avatar
Default Re: Spinning stud need help! (Red_EM2)
I'm not really sure. Some girl hit the front side of my car a couple months ago. All I can imagine is that when she hit my car, the stud must have come loose somehow.
Old Aug 4, 2006 | 06:36 PM
dc2woohoo's Avatar
I don't have air tools to cut it off. What if I drilled a hole in the center of the stud and jammed something in there and held it tight while I loosened the lug? But what could I jam in there that would hold it still? Is there a certain type of punch that would work?
Old Aug 5, 2006 | 08:38 AM
mykcuz's Avatar
first make sure the lug is spinning because its stripped...is the lug the same length as the others? if it is then it is stripped, u need to cut it off, just use a hacksaw blade.
then u have to check if the stud stripped, or if the grooves in the rotor stripped, a lug only costs a buck if that.
tallblondkid
Jun 5, 2011 08:54 AM
liem43
Nov 11, 2005 07:25 PM
shooitzlinh
Mar 20, 2005 06:44 PM
sloazzbimmer
Mar 16, 2005 07:48 AM
ITACivic
11
Apr 14, 2003 04:41 PM
