Honda S2000 Honda S2000
Shifter assy loose??
Old Jun 17, 2004 | 06:37 AM
quickchris's Avatar
Default Shifter assy loose??
A customer of mine just had head work done to his 2000 s2k.Work was performed at a local Honda dealer.Not only did the dealer put close to 1k miles on his car ,but now the shifter assy is all loose.I.E. its in gear and you can move the shifter assy ALL around.BTW they had the car for 5weeks!!!Has ANYONE ever had their shifter assy do this??
Old Jun 17, 2004 | 07:15 AM
blacks2000's Avatar
Default Re: Shifter assy loose?? (quickchris)
Never happened to me. 1000 miles put on the car? I would be so pissed. I don't even know what I would do about that. Charge them 35 cents a mile or something.
Old Jun 17, 2004 | 12:14 PM
LaterApex's Avatar
For the benefit of him and us, he ought to complain to Honda corporate and the local Better Business Bureau.
Old Jun 17, 2004 | 12:23 PM
quickchris's Avatar
Default Re: Shifter assy loose?? (LaterApex)
I think him and his father was taking that route today.He just picked the car up this morning,brought it straight to us.Its not right I know,bad part for that dealer is my customer just got out of training,and he is now a cop.What I think happened was some tool was out in his car and messed it up.I was just wondering if anyone eles had the same shifter problem before.I was trying to help him out,Thanks...I think something is broken
Old Jun 17, 2004 | 12:25 PM
blacks2000's Avatar
I don't know about the shifter thing, but I was at a dealership around me, and saw the techs beating the crap out of cars right in front of the dealership.
Old Jun 17, 2004 | 01:31 PM
LaterApex's Avatar
The shift lever sits in a housing bolted to a small tub that holds the shift rod and shift lever at the top-back of the transmission. Is that what you mean is loose?
Or, do you mean that the shift lever is not engaged to the shift rod and that's loose?
In either case, you may not be able to move it from or to the shift gate.
It' looks like it got beat on by someone that can't drive properly. I hope that his synchros are okay. You've got double-cone synchros on the main shaft and counter shaft that are not at all bullit-proof.
Old Jun 17, 2004 | 01:42 PM
quickchris's Avatar
I think that tub is loose or broken.You can put the car in first gear,and shake the shifter assy left or right about 2 inches in gear!You can shake it (in gear) up and down 2 inches.Hell it may be the shift rod loose or broken.When you drive the car you dont know what gear you are in because its so loose.When I say shifter assy,,,I mean to say shift lever.
Old Jun 17, 2004 | 02:49 PM
LaterApex's Avatar
Sounds like the "L-shaped" shift lever to me. If that's the case, the repair won't be too expensive. It's only $20 over at http://www.hondaautomotiveparts.com.
If it's that, you may want to replace the set-bolt too.
Also, when you put the shifter back together, you may want to pack the shifter ball, ball seat and the pivot cover with a lot of Super Hi Temp Urea Grease. The grease prevents shifter oscillation noise at 3500 to 4500 rpm.
Old Jun 17, 2004 | 06:32 PM
SimbaDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickchris &raquo;</TD></TR><TR><TD CLASS="quote">A customer of mine just had head work done to his 2000 s2k.Work was performed at a local Honda dealer.Not only did the dealer put close to 1k miles on his car ,but now the shifter assy is all loose.I.E. its in gear and you can move the shifter assy ALL around.BTW they had the car for 5weeks!!!Has ANYONE ever had their shifter assy do this??</TD></TR></TABLE>
1000 miles? what were they doin...using it as a test drive/rental car? sue the shiet out of them
Old Jun 18, 2004 | 05:39 AM
quickchris's Avatar
Thanks for your help LaterApex....i will pass the info.I think they will be contacting a lawyer for this crap.Glad im not the service manager there.
v8destroyer
54
Dec 7, 2007 02:29 PM
civic_coupe_585
13
Nov 9, 2007 02:03 PM
jokerstone
Aug 6, 2007 04:21 PM
TurboHondaGuy
Aug 17, 2005 02:20 PM
tdog
Feb 11, 2002 06:35 PM
