Honda S2000 Honda S2000
S2k engine removal
Old Sep 12, 2005 | 12:17 PM
turbos2kguy's Avatar
Default S2k engine removal
what up folks, looked aroung this forum and cant find the procedure to remove the engine, or a service manual. Im getting ready to remove the tranny and pull the engine from the top like i do most cars, but there is a bolt on the top pass. side of the tranny that is too close the the firewall to pull it out. Do you just pull them as one through the top? Or do you have to drop the subframe and drop it through the bottom? Any help is much appreciated.
Thanks
Old Sep 12, 2005 | 12:53 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: S2k engine removal (turbos2kguy)
I jacked the rear up and pulled them both out at an angle. Just make sure the oilpan clears the front crossbeam, and try not to bash the FPR too much. Its a pain trying to disconnect the tranny from the motor while its still on the car; they dont give you enough clearance.
krysted9354
21
Nov 14, 2008 12:57 PM
xrunner86x
Mar 7, 2007 05:19 AM
alupso
24
Jan 24, 2006 12:08 PM
Inaniac
28
Oct 20, 2002 11:36 AM
2K_TEG
May 16, 2002 01:35 PM
