Honda S2000 Honda S2000
Running two inches wider in rear okay?
Old 09-27-2010, 05:58 PM
Liquidgsr's Avatar
Default Running two inches wider in rear okay?
Would it be okay to run 17x7.5 in the front and a 17x9.5 in the rear or is that going to seriously mess up the handling?
Old 09-27-2010, 06:19 PM
bky
bky's Avatar
Default Re: Running two inches wider in rear okay?
tire sizes would be helpful.
Old 09-27-2010, 08:27 PM
He knows where you live!
TheMuffinMan's Avatar
I have 17x8 17x9 and am just fine - but as stated, you'll need to list your tire sizes.
Old 09-27-2010, 11:58 PM
trunkflapper's Avatar
It shouldn't be a problem, with the right sized tires.
Quincy
Old 09-28-2010, 03:31 AM
Liquidgsr's Avatar
Ok correction, what size tire should I run?
Old 09-28-2010, 05:26 AM
S2KILLA's Avatar
Location: Yeah IM from Jersey, big wup, wanna fight about, it, USA
a 225 and 265 sounds about right...
Old 09-28-2010, 06:36 AM
punchdrunk's Avatar
I run 215/255 on 17x8.5 and 17x9.5 rims on Tein Flex's - no issues
Old 09-28-2010, 08:06 AM
Driven's Avatar
17x9 all around with 255s. no problems whatsoever.
Old 09-28-2010, 08:53 AM
Liquidgsr's Avatar
What offset are you all running with those 17x9+ wheels?
Old 09-28-2010, 11:39 AM
wrXtian's Avatar
this is off s2ki and i used it as a reference for when buying rims on deciding the offset and tire sizing.
"For the front:
Offsets lower than +43 are not recommended on the front because a very narrow tire would need to be used to avoid rubbing.
+43 to +47 offset: 205 tires, 6.5" - 7.5" wide wheel
+48 to +52 offset: 215 tires, 7.0" - 8.0" wide wheel
+53 to +57 offset: 225 tires, 7.0" - 8.0" wide wheel
+58 to +62 offset: 235 tires, 7.5" - 8.5" wide wheel
+63 or higher offset: 245 tires, 7.5" - 8.5" wide wheel
For the rear:
Offsets below 40 are not recommended for the rear because a tire narrower than the stock tire would need to be used to avoid rubbing.
+40 to +44 offset: 235 tires, 7.5" - 8.5" wide wheel
+45 to +49 offset: 245 tires, 7.5" - 9.0" wide wheel
+50 to +54 offset: 255 tires, 8.0" - 9.5" wide wheel
+55 to +59 offset: 265 tires, 8.5" - 9.5" wide wheel
+60 to +64 offset: 275 tires, 9.0" - 10.0" wide wheel
+65 or higher offset: 285 tires, 9.0" - 10.0" wide wheel"
Old 09-28-2010, 03:59 PM
murders2k's Avatar
will be fine.7.5 is a skinny rim tho.might want to think about some wheel spacers to get it flush unless your goin to dump it on its face to the point of tucking them 7.5's up front...anything over a 215 tires not gonna look to hott.the tires not gonna sit flush on the rim..an flush is money.my 2 cents.
Old 09-28-2010, 05:16 PM
Driven's Avatar
+48.
6ULRs
Old 09-29-2010, 05:06 AM
Liquidgsr's Avatar
Well here is the thing. I got a set of Work Emotion XD9s 17x7.5 +42 for the front for 180 with tires on them already. So I am debating on what to go with for the rear.
Old 09-29-2010, 07:43 AM
Driven's Avatar
sell those for $250 and get some wider wheels.
Old 09-29-2010, 08:46 AM
Gixxergod's Avatar
Noiceeeee
Old 09-30-2010, 11:00 AM
veilsides2000's Avatar
This.
Know a couple of owners down here that run very similar setups and handles like a charm.
Old 10-07-2010, 11:22 AM
Liquidgsr's Avatar
Ended up selling them and going to go with a 17x8+48 and 17x9+35. Any recommendations on the tire size that I should run?
Old 10-07-2010, 12:29 PM
murders2k's Avatar
are you lowered or stock? them offsets are goin to be tricky if you dont kno what your doing.im about to post my wheels up forsale if you would like to get first dibs on a set of s2k fitment wheel.give me more info on your car an i can help as much as possible,.
Old 10-07-2010, 01:00 PM
Driven's Avatar
I'm thinking the rear might have a problem.
with 245s in the rear, and +45, it's okay.
with 255s in the rear, and +45, it's okay at stock height.
anything lower offset or lower ride height and I can imagine running into some issues.
Also, this is assuming you do a bumper tab relocation. minor fender roll is recommended, but I have heard people get by without it.
Old 10-07-2010, 06:30 PM
Liquidgsr's Avatar
Car is stock right now, but I just purchased JIC Magic coilovers to put in. I am aware that I will need to roll the rear fenders and do a bumper tab relocation also run some negative camber if necessary in the rear. The car is not my daily driver.
Old 10-07-2010, 11:21 PM
liljohna103's Avatar
im running 18 x 8 in front with +48 AND 18 x 9.5 in rear with +50 and it rides great rubs but rolled the rear fenders 225/40/18 front 245/40/18 rear
Old 10-08-2010, 03:36 AM
Liquidgsr's Avatar
Are you lowered at all?
Old 10-08-2010, 09:00 AM
murders2k's Avatar
roll fenders/pull fenders relocate tabs stretch tires an massive camber should do it lol.even with all that done your rears are gonna be so cocked in at the top due to camber its gonna chew your tires to ****.good luck an post pics when your set up is complete.just keep in mind the lower you go the more camber is needed.
Old 10-15-2010, 06:07 PM
eg6forlife's Avatar
sick s2k offset...
eg6forlife
Old 10-16-2010, 05:00 AM
I Deliver
EJAYATE's Avatar
I run 225 in the front and 255 in the rear on stock ap1 wheels
rocko5845
01-19-2010 11:02 AM
Frog
04-08-2009 11:24 AM
Ben Ogle
08-18-2005 07:31 AM
Powered by Honda
12
08-04-2005 04:47 AM
BlazinITR
02-10-2003 06:55 PM
Quick Reply: Running two inches wider in rear okay?
