problem with vtec engagement...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00N »</TD></TR><TR><TD CLASS="quote">when i down shift to first and hit vtec my engine shuts off... any ideas?</TD></TR></TABLE>then dont downshift to first
just stating the obvious since there isn't a lot of info to work with, try installing the stock header and see what happens
If the install went properly, I can't see a reason why your having issues. A wire could've been damaged in the install, a connector unplugged and not plugged back in. It could be many things.
doubtful that it's the header. perhaps theTB if anything at all due to the TPS sensor, IIRC on the S. Not sure how adjustable it is, but it must be tuned correctly.
Can you describe the scenario a bit more? Going at X speed, downshift to 1st... then what?
Do you blip the throttle at all?
[QUOTE=SP00N]when i down shift to first and hit vtec my engine shuts off... any ideas?[/QUOTE=SPOON]
U down shift to first??? How fast were u going???
Modified by $pecial K at 12:17 PM 6/4/2004
sorry, i'll try to be a little more detailed.
when the intake and TB was installed NP's.
after the header install, installed by Honda,
the engine will gradually shut itself off when i hit vtec.
it isn't always downshifting to first at any speed that does it. sometimes i just launch it in first, (full throttle after the initial wheel spin, and when vtec comes along, the rpms start moving backwards. hope thats detailed enough
so your dealer installed the header? if so, have you asked them why you're having problems?
well if it helps, i pmed him the same question, he said it's not the header install and if he wants them to look at it they'll go head and charge him up the ***. in my own words anyway
ophdehEEzY
Apr 27, 2003 08:01 PM
