Honda S2000 Honda S2000
Official Alignment Setting Thread.
Old Oct 19, 2006 | 08:42 PM
Francesco's Avatar
Default Official Alignment Setting Thread.
Please post your alignment settings with rim/tire sizes/drop. This is mainly for members with aftermarket rims who are looking to try out new setups.
UK Alignment:
Front:
Caster Left = 6 degrees 45"
Caster Right = 6 degrees 45"
Camber Left = -1 degree 00"
Camber Right = -1 degree 00"
Toe Left = 0
Toe Right = 0
Total Toe = 0
Rear:
Camber Left = -2 degrees 00"
Camber Righ = -2 degrees 00"
Toe Left = 0 degrees 20"
Toe Right = 0 degrees 20"
Total Toe = 0 degrees 40"
Comments
- Gives my s2000 a more neutral feel.
- I rub with a 225 tire in the front though.
- Im also on a 2'' drop in all four corners.
- ce28's (17x7.5 +50 / 17x9 +63)
I want to add more -camber to the front or get ASM front fenders.
Modified by Francesco at 9:38 AM 10/20/2006
Modified by Francesco at 2:51 PM 10/20/2006
Old Oct 19, 2006 | 08:56 PM
LAS2K's Avatar
Default Re: Official Alignment Setting Thread. (Francesco)
you forgot to add how much of a drop you are on.
Old Oct 20, 2006 | 05:38 AM
gomarlins3's Avatar
I am on the UK specs as well, but I am not sure how far I am lowered. I never measured before did the first or second drop.
Francesco's Avatar
Default Re: Official Alignment Setting Thread. (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">you forgot to add how much of a drop you are on. </TD></TR></TABLE>
Fixed. Thanks for the reminder.
Hows the Flex going? PM me. Keep this thread all about alignments.
Old Oct 20, 2006 | 10:28 AM
Tyson's Avatar
offsets?
Old Oct 20, 2006 | 10:51 AM
Francesco's Avatar
Default Re: Official Alignment Setting Thread. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">offsets?</TD></TR></TABLE>
To the top.
Old Oct 20, 2006 | 01:42 PM
MidwestAutoWorks's Avatar
I just went with stock on my Eibachs.
Old Oct 20, 2006 | 08:00 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Official Alignment Setting Thread. (MidwestAutoWorks)
dont knwo how much im dropped but im stilling on my Volks...
dont know my casters but my cambers are
Front -2 degrees
rears -1
Volk CE28n's
Volk LE37's
both 17x7.5 front 50 offset, 17x9 rear 63 0ffset
215front/ 245 rear..
i also ran 235x45 fronts as well
Old Oct 21, 2006 | 05:43 AM
JDM knowledge's Avatar
Default Re: Official Alignment Setting Thread. (S@nt0s)
i have to find my sheet.
I wanted mine set to the UK specs but i have a frozen bolt on my driver side LCA. So my **** right now is all wacky.
Old Oct 26, 2006 | 12:18 PM
evil vapor's Avatar
Default Re: Official Alignment Setting Thread. (JDM knowledge)
My "track" settings. Stock '01 suspension (shock, spring, sway bar). Car may sit a touch higher since it's stripped. Car weighs about 2500lbs without driver 1/2 tank gas.
For reference, tires used 275s in the rear, 225s in the front.
Front:
Caster: 5.66 degrees
Camber: -2.00 degrees
Toe: 0"
Rear:
Camber: -2.25 degrees
Toe: 1/16" total (1/32" each side in)
Old Oct 26, 2006 | 03:11 PM
- BSeRiouS -'s Avatar
Default Re: Official Alignment Setting Thread. (evil vapor)
Euro Spec Alignment:
Front:
Toe Left = 0
Toe Right = 0
Total Toe = 0
Rear:
Old Oct 26, 2006 | 04:10 PM
papa5murf's Avatar
Default Re: Official Alignment Setting Thread. (OBSeRiouSo)
dropped 2+ inches.. (don't know exact)
Front:
caster 8.2
camber -1.6
toe 0
Rear:
camber -2.6
toe 40
Old Oct 27, 2006 | 10:34 AM
evil vapor's Avatar
Default Re: Official Alignment Setting Thread. (papa5murf)
also keep in mind when getting an alignment, it helps to sit in the car while the tech makes the adjustments since an extra 140-200lbs will make a difference on the specs.
Old Oct 27, 2006 | 09:42 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">also keep in mind when getting an alignment, it helps to sit in the car while the tech makes the adjustments since an extra 140-200lbs will make a difference on the specs. </TD></TR></TABLE>
Im 95lbs, but I am going to have the tech let me sit in the car because I plan to track my car once the new parts are bought.
Do you think ill have any issues if I increas the -camber in the front with the euro alignment? im thinking -1.5 or -2 in the front.
Old Oct 30, 2006 | 11:53 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
Do you think ill have any issues if I increas the -camber in the front with the euro alignment? im thinking -1.5 or -2 in the front. </TD></TR></TABLE>
95lbs? wtf, eat more food.
As far as issues, that depends on your driving style. I don't think there is a perfect alignment setting. You're best bet is try different settings that you find ideal with your driving style at the limit of traction around a corner.
Old Oct 30, 2006 | 01:53 PM
Ferrell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">Im 95lbs </TD></TR></TABLE>
And I thought I was small at 140 lbs.
Old Oct 30, 2006 | 04:01 PM
kmart888's Avatar
Well I have stock ’02 S2000 wheels and suspension so this may not be pertinent but I thought I’d throw it out there anyways. I’ve had my s2000 for a little over one week and I’m already changing the settings; I thought the car had too much snap over steer for the street where I occasionally must lift in the middle of a blind high speed sweeper so I tried some setting that worked on my Miata. -1.0 deg camber, 0 deg tow in, 6.1 deg caster in front and -2.2 deg camber 0 deg toe in rear. This helped a tiny bit but not much so I replaced the 225/50x16 Hankook K104 rear tires with 245/45x16 Toyo TR1’s hoping to gain some grip at the rear but it actually over steared WORSE and it was a handful to keep straight at 90mph! After several hundred miles I checked my air pressure thinking the rear tires might be low and found they were at 45lbs (installed by Super Autobacs in Stanton CA) so I dropped them to 34lb’s and checked that the fronts were still at 32lb’s and all was right again. The car now feels perfect (personal preference) and I can it around at will with no fear of unintentionally looping it, great fun! I had no idea that the S2000 would be so sensitive to minor changes in tire pressure!
Old Oct 30, 2006 | 08:28 PM
evil vapor's Avatar
Default Re: Official Alignment Setting Thread. (kmart888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kmart888 &raquo;</TD></TR><TR><TD CLASS="quote">Well I have stock ’02 S2000 wheels and suspension so this may not be pertinent but I thought I’d throw it out there anyways. I’ve had my s2000 for a little over one week and I’m already changing the settings; I thought the car had too much snap over steer for the street where I occasionally must lift in the middle of a blind high speed sweeper so I tried some setting that worked on my Miata. -1.0 deg camber, 0 deg tow in, 6.1 deg caster in front and -2.2 deg camber 0 deg toe in rear. This helped a tiny bit but not much so I replaced the 225/50x16 Hankook K104 rear tires with 245/45x16 Toyo TR1’s hoping to gain some grip at the rear but it actually over steared WORSE and it was a handful to keep straight at 90mph! After several hundred miles I checked my air pressure thinking the rear tires might be low and found they were at 45lbs (installed by Super Autobacs in Stanton CA) so I dropped them to 34lb’s and checked that the fronts were still at 32lb’s and all was right again. The car now feels perfect (personal preference) and I can it around at will with no fear of unintentionally looping it, great fun! I had no idea that the S2000 would be so sensitive to minor changes in tire pressure!</TD></TR></TABLE>
you'll get throttle lift oversteer in any car, even a front wheel drive car with 75% weight distribution over the front half of the car if you lift midcorner while accelerating (weight on the rear wheels regardless). There is NO alignment setting, tire pressure setting, limited slip differential type, shock/sway/spring combo that will change TLO.
Old Oct 30, 2006 | 11:38 PM
WowOzYouRock's Avatar
i think hes tryna maintain his perfect body ... 24-24-24 ROFL
ok lets back to the topic
Old Oct 31, 2006 | 05:24 AM
Francesco's Avatar
As far as issues, that depends on your driving style. I don't think there is a perfect alignment setting. You're best bet is try different settings that you find ideal with your driving style at the limit of traction around a corner. </TD></TR></TABLE>
I agree with you there. What setting I may like you may hate, and vice versa.
Old Nov 2, 2006 | 10:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">Im 95lbs</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">95lbs? wtf, eat more food</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">i think hes tryna maintain his perfect body ... 24-24-24 ROFL</TD></TR></TABLE>
hahhahaha. Geeze I got twice the weight and some change on you. lol
Old Nov 20, 2006 | 05:51 PM
Francesco's Avatar
I might try this out next time around, its not much different than my current Euro Settings.
Front:
Camber -2.5*
Castor: 6.5*
Toe: 0"
Rear:
Camber: -3*
Total Toe-in: 1/8"
Old Nov 20, 2006 | 07:08 PM
Mr. Projekt's Avatar
* B A N N E D *
Front:
Caster: 6 dg
Camber: 1.2 dg
Total Toe: 0
Rear:
Camber: 1.8
Total Toe: 0
Stock AP2 wheels, Yokohama Advan A048s 225F/255R
00-01 AP1 spec anti-sway bars: 27.2mm F/R
I've grown to love the ZERO toe. It's neutral with a little throttle, tail happy with a lot.
Old Nov 20, 2006 | 10:46 PM
evil vapor's Avatar
Default Re: Official Alignment Setting Thread. (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Front:
Caster: 6 dg
Camber: 1.2 dg
Total Toe: 0
Rear:
Camber: 1.8
Total Toe: 0
I've grown to love the ZERO toe. It's neutral with a little throttle, tail happy with a lot. </TD></TR></TABLE>
have you encountered a bump midcorner while on the throttle? Bumpsteer was corrected slightly in the ap2
Old Nov 20, 2006 | 11:27 PM
* B A N N E D *
Bump steer has not been a problem at all, even if I hop a few candy stripes.
